Results 1 to 12 of 12
    Non-member danr5Gtt's Avatar
    Nov 2014
    Piper Cam kit
    Hi all,
    I am soon to take the standard engine out of my Ph2 for a bit of a tidy up in the bay etc...
    Whist the engine is out I am in two minds weather to do a few upgrades. Nothing too crazy, but just as a starter and then take it from there.
    So I am thinking 285 Piper cam kit?
    Where is the best place to get one from?
    The Carb is also going to get a service and set up to. Of course got the service kit from the rtoc shop
    AFR is already to go along with the downpipe.
    What else would you recommend doing whilst the engine is out without going over board?
    Many thanks Dan
    Re: Piper Cam kit
    I bought mine direct from Piper but that was a while ago.
    It would be worth taking the gearbox off and checking the clutch for wear. Also check all pipe work and hoses and replace any awkward ones. Maybe give the engine and engine bay a clean up
    Nov 2014
    Re: Piper Cam kit
    Thanks Alex,
    Should also have said I,ve already replaced pistons,liners with tarabusi ones,clutch has also been done,new valve steams too, red samco hoses all round. Have some more to add whilst the engine is out too.
    I'll take a look at the Piper site.
    Dec 2004
    Aylesbury
    Re: Piper Cam kit
    What turbo you going to run on the car?
    Nov 2014
    Re: Piper Cam kit
    It's a standard one at the moment. Open to suggestions....
    Dec 2004
    Aylesbury
    Re: Piper Cam kit
    I would only go 285 cam if your going big turbo
    If you want response then I would go Piper 270 cam with a moderate size turbo, T2/T25 something like that
    I have even used a 270 with a large turbo, works very well too
    Nov 2014
    Re: Piper Cam kit
    Thanks Mark,
    can I still go with a 285 cam and then upgrade the turbo at a later date?
    Dec 2004
    Aylesbury
    Re: Piper Cam kit
    Quote Originally Posted by danr5Gtt View Post
    Thanks Mark,
    You can but decide what turbo you want first before buying the cam, try suit them to each other
    Nov 2014
    Re: Piper Cam kit
    Ok cool
    Thinking about a T28, just need some ideas before I go ahead really.
    Dec 2004
    Aylesbury
    Re: Piper Cam kit
    T28 is good for outright power, you after big power or more response?
    Nov 2014
    Re: Piper Cam kit
    Not mas power really Mark, just options really which I can build on.
    Thanks
    Re: Piper Cam kit
    A T25 is usually a good compromise between outright power and driveability on the road.
