Results 1 to 23 of 23
    Feb 2015
    5 is playing up indicator light staying on??
    as titled really.
    so yesterday I go for a blast come back and all lights are working perfect but one. the rear lamp indicator is staying on (not flashing) when the side lights are on???? random. and when I press the brake the brake light doesn't come on at all. iv changed all the bulbs .anyone had this before??
    I want to go to pod this weekend but ima get a nick on the way home if they arnt working.
    any one!!!!
    Feb 2015
    Re: 5 is playing up indicator light staying on??
    no lights up on the dash....
    Non-member Leigh5T's Avatar
    Nottinghamshire
    Have you tried taking the rear clusters out and cleaning the contacts?
    They're usually corroded so a little wire bush normally solves it.
    Mine used to do a similar thing. Brake lights flashing when indicating and all sorts.
    Feb 2015
    Quote Originally Posted by Leigh5T View Post
    yeah tried that this evening.....
    evan tried another set of rear lamps.....
    Norwich
    Sounds like corroded contacts or a bad earth for the rear lights that needs cleaning up...
    Apr 2014
    Quote Originally Posted by Milky View Post
    as titled really.
    any one!!!!
    That looks like an earth issue somewhere. The negative path to the side light circuit is false feeding the indictaor and using the earth of that circuit.
    Non-member tubbyG's Avatar
    Dec 2010
    Quote Originally Posted by Matt_S View Post
    Feb 2015
    cleaned and checked every earthing point and still the same issue.....
    Stalk could be faulty.
    Feb 2015
    also have replaced both looms eitherside.
    bloody five has done nothing but mess my year up. iv missed so many meets and events because it lets me down..... think ima sell up soon. only been back in one a year and already fed up lol
    Feb 2015
    I thought about that. tried spraying circuit cleaner in it with no change.... will fit another tomorrow and see. poxy fecking thing......
    Feb 2015
    earthing points - have I missed any??
    -rear of headlights
    -behind dash
    -aei
    -rear engine
    -battery
    -centre console
    Feb 2011
    Down South
    flasher unit? is there a relay for flashers?
    Non-member MR TURBO's Avatar
    bristol
    I think there is a relay for that don't quote me tho.... U not got a Haynes manual?? Would make a good investment... I'm sure in the back in the wiring diagrams it shows the relays I think
    -rear of headlights
    -behind dash
    -aei
    -rear engine
    -battery
    -centre console
    Engine earths (if they are of any use):
    Water pump to bulkhead
    Front engine loom to block (just below oil sensors)
    Gearbox to suspenson leg
    Battery to bulkhead
    Isn't there an earth on the rear lights as well
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Yes , on mine passenger side iirc. Bolts to the inner wing / wherl arch.
    Feb 2015
    thanks for the replys .
    iv got a Haynes and have cleaned all earths 100% now
    its now worse. when I brake the fuel pump cuts out. both rear lights are constantly on. iv checked all connecters and clips and have cleaned . im stuck....
    iv evan added extra grounds /earths to both rear lights and fuel pump. still the same issue....
    Dublin/Ireland
    alternator + connection?
    Nov 2010
    Burntwood Staffs
    There will be x2 earth on your flasher relay. one will go to a main earthing point and the other is the earth for the hazard switch. check those.
    (clutching straws here and this one is very doubtful as the clocks are ok) but on the back of your clocks on the far left hand plug as you are looking at it from the drivers seat check that, give it a wiggle as there is an earth there.
    Check the connections on your light stalk. perhaps unplug the connections from it and see if the car still cuts out.
    Dec 2012
    Had similar with my monaco clocks same far left connector. Was on but not connected properly. The left brake light didnt work and mine had a fog light permantly illuminated in the dash but not outside. Hope its something simple, wiring can be a pain.
    Nov 2010
    Burntwood Staffs
    Yes, that plug is a massive pain in the bum. well, its not actually the plug but it is the connections the plug attaches to. If it is that a good clean of the contacts and some brute force should see you right.
    Connector of doom?
