Results 1 to 10 of 10
    Non-member j4ck-dw's Avatar
    Dec 2011
    map
    has anyone got a finished map i could use just as a tempory measure ive got i base map but it literally cuts out once the car is hot and wont start again until its cold any ideas ????? i was gonna see if i could load a finished map on there an see how i get on the spec as follows :
    micheal t manifold
    bosch red injestors
    t28 turbo
    285 cam and pulley
    any advise apprecitated
    Dublin/Ireland
    Re: map
    i'll send 1 in a while......send email address
    Dec 2011
    Re: map
    nice one buddy
    Re: map
    Could be coolant compensation
    Re: map
    I have maps but not for a C1J, I don't mind taking a look at your map if you email me a copy over
    Non-member royz's Avatar
    stockport
    Re: map
    got a map to the same spec you can have a try of
    Dec 2011
    Re: map
    Quote Originally Posted by royz View Post
    yeh if you wouldnt mind is this just the base map or mapped on the rollers
    stockport
    Re: map
    sorry for the late reply.
    might have a slight problem just remembered I have mine set up to run sequential injection. where I use the standard Renault wheel for triggering and a senor attached to what was the old dizzy to give the ecu a reset point. so might not work. I have the base map that was sent to me so I could at least run the car and get it to EFI parts when I then had it fully mapped.
    Dec 2011
    Re: map
    Hi got it running ok with the map mike emailed me but still running very rich I'll send it over what's your email cheers 👍👌
    International Area Rep
    Jul 2009
    Hungary
    Re: map
    May I also ask those maps?
    I'm having some jerkiness as I get on and off the trottle and I think that my decel area is not good mapped.
