Results 1 to 4 of 4
    Non-member kial's Avatar
    Jan 2011
    Jersey, C.I.
    Saxo power steering pump
    I have the one with the bottle seperete, does anyone know are the fluid bottles gravity fed?
    Where I have the pump fitted in the bulk head the bottle is next to it with the pipes obviously going down then back up to go into the pump. Now worrying if there gravity fed I'm going to have a issue.
    Thanks
    Member robw's Avatar
    Re: Saxo power steering pump
    That setup was a nightmare for me, I ended up getting the other pump with the container built in
    Jan 2011
    Jersey, C.I.
    Quote Originally Posted by robw View Post
    Guess it is gravity fed then. I'm sure someone on here has this same one fitted?
    Yes gravity fed. But getting it to fit in there isn't really possibly I found. I played around with it for a fair while but it leaked. In the end just changed it. So much better now.
