Results 1 to 4 of 4
    Non-member Mattw's Avatar
    Jan 2010
    Burghfield common
    Fan switch
    I'm wanting to run a switch for my Rad fan but keep it on the temp sensor too. So on track constant on and on the road she can sort herself out. Anyone have a diagram or any ideas best way to do it. Many thanks ��
    Non-member Junglist's Avatar
    Dec 2008
    Chester
    Re: Fan switch
    I guess you could just put 2 wires on the wires that go to the fan switch in the rad then straight to a switch in the car.
    Re: Fan switch
    Can't see it making any difference mate. The air flow through the rad at speed will be greater than the flow rate the fan can deliver.
    Jan 2010
    Burghfield common
    Re: Fan switch
    I see your point but it will still run normally too but I have the option.��
