Results 1 to 10 of 10
    Feb 2011
    Down South
    changing clocks mainly speedo
    hi all, right thinking of buying some clio mk1 clocks because of the cable speedo, as we now have a jc5 box and fitting all the white clocks in the gt dash but after close inspection ive noticed that all the connectors are out, I will be able to mod the clock to fit in easy but want them all to look the same so what im asking is can I change the white clio ones for the orange gt ones??
    anyone done this before, ive striped loads of clocks but not clio ones so not sure how they fit on the plastic pods
    any help apprec thx mick
    https://www.rtoc.org/boards/attachmen...1&d=1434296693
    edit just noticed some are electronic typical
    Re: changing clocks mainly speedo
    Mick, you want to message Mr Smith
    He removed a valver speedo and put it into the 5 clocks, think it needed a few mods but nothing major, he had some pic's of what was needed
    https://www.rtoc.org/boards/member.php?u=240
    Just messaged him on facebook Mick
    Feb 2011
    Down South
    thx jim will do typical ive just checked ebay and they did 1 with a digital feed too
    couldnt of had that 1 could we, been checking all day and cant find out what the 3 wires coming from the analogue speedo cable are for ones a earth though
    ill pm now thx mr sargent apprec
    EDIT pm done looks like the 3 wires are for a valver so probably not used but looks like they were wired into the adaptronic james, the wires i removed i think were for it
    Got a response for you.
    Just remove original gt clocks including ribbon cable. Drill rear of housing to accommodate mechanical drive, you'll need a packer to get mechanical speedo sitting flush in housing. Note link wire required as pictured to keep clocks illuminated
    Can't Seem to upload pics from my mobile I'll upload to PC later and try in meantime I have WhatsApp you buddy
    Feb 2011
    Down South
    thx james pity bout the turbo gauge on rev counter grrrrr
    Feb 2011
    Down South
    uploaded for you
    what are the 3 wires on the speedo cable??
    anyone??
    black, yellow and white
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    I think I've still got the clio clocks that was connected to that Mick.
    Feb 2011
    Down South
    could you check boss loom in almost ready for lift off pmsl
    Mar 2002
    East Sussex
    I will dig it out this weekend. Speedo worked before I took it out.
