Results 1 to 11 of 11
    Non-member Cr23g's Avatar
    Aberdeenshire
    Connector guessing game
    Hi folks.
    a few last connectors that have elluded me, anybody want to put me straight on these please?
    Thanks again mike for the new loom
    first one is in-between the heater thumb screw and the heater face illumination bulb
    does the standard head unit require an adaptor as this is what i am left with
    i have done a bit of digging and read this does nothing??
    last two are hanging around the ignition barrel
    Aberdeenshire
    Re: Connector guessing game
    Cool points still up for grabs folks
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    I think I did a guide somewhere with all loom connections labelled up! Or maybe it was just engine loom.....
    Non-member Goobie's Avatar
    Mar 2002
    East Sussex
    First one I think is for the clock?
    Second one is after market stereo loom adapter, one is for the speakers and the other for the power supply.
    Third picture is for the cigarette lighter.
    Fourths connects to the under dash tray that has a rolling dimmer switch so to speak, it adjust the brightness to all the dash lights.
    I WIN!....
    Non-member Hoolio's Avatar
    Wallingford
    Excellent info.
    Aberdeenshire
    Thanks very much for the info, however the cig lighter and the clock is already wired up and working
    With regards to the stereo photo. The red connector is obv part of the dash loom, but is this not standard? The two black connectors come from the stereo itself.
    I do remember seeing an engine loom picture liam. Also came in handy
    Nov 2008
    Isle of Man
    I'd say you were right with the first being heater controls!
    Aberdeenshire
    yeah the 4 pin plug goes to the thumb screw and the bulb also goes to the heater control but what the plug I'm holding goes to I'm still not sure
    Aberdeenshire
    so the 3 pin plug i am holding must be where the fan gets its power from? these 2 plugs and the bulb are on one harness which goes to the heater fan. but can't find any other plug to connect to
    Aberdeenshire
    i was right enough, it was the fan power feed, took the dash back off to find it was stuck in-between the dash and the fan housing, pulled it back through and ta-da!
    Member Thundercat's Avatar
    1st heater, 2nd stereo iso plugs, 3rd auto box illumination/inhibit not sure, 4th dash lights adjuster.
