Does anyone know where I can get Total Seal Piston Rings and what the correct Total Seal part numbers are for std 76mm bore C1J Pistons?
Been a while since I got a set but try these guys http://www.performanceunlimited.co.u...-piston-rings/ best thing to do is measure the existing rings height and width as bore size you know and they will sort set for you
Thanks James, that was the plan, but if someone had a part number it would set my mind at ease.
You could give CTM Performance Heads a call as he may have fitted some to a 5GTT one of them had maybe 10 years ago, but he may not know now. IIRC, he had, or was trying to get, the UK top level dealership for Total seal rings.
https://www.rtoc.org/contacts/?id=6
Or, would Scoff know?
Thanks Ian, I'll send them an email too.
I did keep them in stock
I spoke to CTM today as I was there regarding something else and they told me they haven't had Total Seal Rings for maybe 10 years.
How time flies!
