Results 1 to 4 of 4
    Non-member Rockets1971's Avatar
    Jan 2014
    9 Turbo phase 2 Speedo, Mileometer/ Oil gauge problems
    Hi everyone.... Got a real problem on my hands... The 9 Turbos speedo, odometer and oil pressure gauge aren't working.... We've checked everything, connections etc. replaced the upper and lower speedo cables and the oil pressure sensor with new ones. Power is flowing as far as the dash panel at which point it dies... I have been told that it is normally the copper tracks on the dash panel that through time crack.
    My question is, can this be fixed?
    Really starting to bang my head off brick walls here so any help would be really really appreciated! Really need to get these working.
    Re: 9 Turbo phase 2 Speedo, Mileometer/ Oil gauge problems
    Try a different set of clocks?
    Jan 2014
    Any ideas where I might be able to track down a decent set?
    eBay and the classifieds I would say. The R9/11 have slightly different clocks to the GTT but I imagine the printed circuit on the back is much the same. You could buy a GTT and swap the circuit over or just have the GTT style clocks.
