Guys,
I want to upgrade my suspension on my phase 2, which is currently standard. I use the car for fast road driving only and would like to lower the car but only very very slightly as I want the car to appear as close to standard as possible.
What are my options? I understand that the koni's are a good buy but are there any others I should consider? Also, will I need to specify a spring height or do the kits come with one spring height that you can adjust? Finally, when I replace the suspension should I replace anything else, bushes or anything?
Thanks in advance
