Results 1 to 6 of 6
    Nov 2011
    Fuel hose, from tank to pump.
    In need of a replacement hose, the one that goes from the sender unit at the top of the tanks to fuel pump.
    Thanks
    Nov 2011
    Re: Fuel hose, from tank to pump.
    Anyone got one lying around?
    Surely you won't really want to be replacing it with a 2nd hand one? Try a local motorfactors and ask them for some high pressure fuel hose, it's only cheap
    Nov 2011
    The oe ones tapered, large at one end than the other. I cut mine thinking I'd replace it with a new hose, oops
    If it's tapered it's not by much. I think 8mm is what you need of just take an old piece with you.
    Nov 2011
    The oe hose is 10mm ID at the tank end and 12mm where it attaches to the fuel pump.
    I'm going to fit a reducer to the cut hose and a small lengh of 12mm fuel line, until I can source a second hand oe one.
