Results 1 to 2 of 2
    Mar 2013
    starting issue
    been out today in the 5 had a right good boost out...... batt light been flickering for some time now till I stoped her today...went to start her all lights came on dash turned key and nothing no clicks just nothing ??? ive replaced starter few months ago the car starts with a bump but when running now the batt light is out and I can here a slight noise when let throttle off
    Norwich
    Re: starting issue
    Has the white exciter/signal wire come off the starter motor?
    There's also a wire that runs from the alternator to the starter motor. Would check exciter wire through the conector of death behind passenger side headlight and also all alternator wiring and starter motor wiring.
