Results 1 to 9 of 9
    Non-member stu21t's Avatar
    Why has my speedo stopped working?
    It was working fine them just stopped.
    I've tried a different set of clocks, it's not that.
    Unplugged the joint and cleaned it up, still not working.
    It feels like it's in the gearbox properly
    What's next to check?
    Non-member RussellT's Avatar
    Blackpool
    Re: Why has my speedo stopped working?
    in my experience sack the joint and join the wires with a simple block conector.
    Norwich
    Get the pick up out of the gearbox, held in by a small bolt/clamp near the exhaust downpipe. It might need a clean up .
    Clean up or replace the connection near the air filter/suspension turret and clean up the connection at the back of the clocks. If it still doesn't work inspect/replace the sensor itself.
    Cheers guys, will take a look.
    Blackpool
    Honest sack that black connector, its poo, before you do anything else, easy job to do.
    Yep will do that this weekend.
    Can I test the connector at the dash end at all?
    May 2014
    Guess only way to test the connector would be to use a continuity tester or test lamp to check the wiring from the engine bay connector through to the back of the speedo.
    My speedo has been flakey for ages so i need to do the same at some point. It comes to life if i wiggle the wires in the engine bay, so i think i will just replace the wiring with some new stuff.
    Blackpool
    my advice is dont touch anything until you have changed the connector. If it still doesnt work then look elsewhere.
