Results 1 to 16 of 16
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Not charging!
    On Big-Steve's car the alt is only giving out 6v max. He's tried a tested one and a new one but is still getting the same.
    The voltage is being taken from the alt its self and at the battery. Anyone know the pops?
    The wires that are on it are... One to the starter and one to ground, if that helps make it clearer.
    Cheers guys
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Not charging!
    Cheers guys
    has the alt got a good earth. are the top two wires round ther right way.
    Milton Keynes - ish
    Re: Not charging!
    He's going to try an earth from the alt straight to some metal work.
    I'm on the mobile-blower to him doing this so its a bit akward...
    We only want to go to Ace
    Jan 2004
    BEDFORD
    Re: Not charging!
    try it straight from alt to battery just to make sure of good connection. and check the top two wires
    Milton Keynes - ish
    Re: Not charging!
    Which way round should they be mate?
    Is B+ to the starter and B- to earth?
    Jan 2004
    BEDFORD
    Re: Not charging!
    puple near the rad white towards the bulk head
    Milton Keynes - ish
    Re: Not charging!
    Erm, he has Red and black with a white strip
    Is the one near the rad earth?
    Jan 2004
    BEDFORD
    Re: Not charging!
    i would say so try them both ways just to eliminate that make sure you get a reading when doing so
    Milton Keynes - ish
    Re: Not charging!
    He's swapped them and its just sparking like a beeech!
    Gutted.
    Jan 2004
    BEDFORD
    Re: Not charging!
    did he just suddenly get 6v hence he wanted to change the alt. or has this problem only occured because of changing the alt. also do the volts change when revved at all can he get more than the 6
    Milton Keynes - ish
    Re: Not charging!
    Cool, cheers for your help mate. He's giving up for tonight (defeated).
    He done some tiding up in the bay and its happened since then. Clasic 'if it's not broke-don't fix it!'
    Jan 2004
    BEDFORD
    Re: Not charging!
    he has some good pics in his profile he can use as reference mate as you can clearly see the alt
    Milton Keynes - ish
    Re: Not charging!
    I don't think he has any pics up of it. He's sorted it today. Turns out he didn't have the little plug with the purple and yellow cables there at all.... I don't know what he done with it but its all good now
    Dec 2004
    Aylesbury
    Re: Not charging!
    Had to be something simple
    Jan 2004
    BEDFORD
    Re: Not charging!
    thats the two wires i was going on about mate glad its sorted though
    Milton Keynes - ish
    Re: Not charging!
    Yeah, I knew what you ment after looking at mine but it was a mission doing it down the phone
    And cheers Mark for your help too mate
