Results 1 to 6 of 6
    Non-member Corty's Avatar
    May 2014
    Barnstaple
    grp A carb - rebuild kit?
    hi all i have been told i have a group A carb on my raider
    i found today that it is leaking fuel
    possibly the seals have gone on the enrichment circuit or the bowl is leaking?
    havent looked properly yet
    can i use a standard rebuild kit for this?
    im guessing group A means its a solex thats just had the internals modified for more boost ? (it has a KTec 180 turbo )
    also where would i get a seal kit for it ??
    thanks in advance
    Corty
    Dec 2004
    Aylesbury
    Re: grp A carb - rebuild kit?
    The grp A carbs from tuners are just standard carbs with the venturi bored out and jetted very poorly (most of the time)
    A standard seal kit will fit them although i would look into replacing the venturi with a standard size one if it was mine
    May 2014
    Barnstaple
    so would you say its best to get the service kit off here or from my local Renault dealer?
    Dec 2004
    Aylesbury
    Quote Originally Posted by Corty View Post
    From here will be fine mate, prob find it almost the same kits
    Buy from here, you're much more likely to get the right stuff!
    Norwich
    Standard carb rebuilt with the rebuild kit and jetted to suit is all you need, no need for group a carbs really .
