Results 1 to 3 of 3
    Farnborough
    Bling Bits !
    Used chrome heater matrix cover (is that what you call it ?), small indent as you can see in the top of the photo. Used chrome inlet manifold heatshield. Both in good condition. £10 each
    Used Samco red oil drain hose £7
    New, as in never used since being chromed, Rocker cover from CGB. This has had the brackets removed before chroming to give a neater look if you are not running the OE pipe setup. Has had a gasket fitted but never bolted to an engine. As you can see the chrome is a little textured in a couple of areas, basically because they never polish these properly before chroming !. Take a look at the second pic to see what I mean. £80.
    Postage to be added or you can collect from Farnborough in Hampshire. Please PM for any more info.
    Re: Bling Bits !
    Pm ref inlet heatshield
    Farnborough
    Re: Bling Bits !
    Heatshield Sold.
