Results 1 to 10 of 10
    Non-member Coops's Avatar
    Soft Pedal Conversion
    Got another of these for sale
    everything needed included
    £25 posted
    cheers
    Ben
    Non-member LeccyBlue5's Avatar
    Mar 2013
    Re: Soft Pedal Conversion
    This for a c1j? Work on a phase 1 r5 turbo?
    Quote Originally Posted by LeccyBlue5 View Post
    Dude it will be of a newer model clio 172 or similar but yes it will bolt and fit the 5 no problem, to fit you will need to seperate engine and box, change the clutch bearing to the clio one and insert the longer clutch arm, and also bolt the extender bracket to out side of box
    May 2014
    Coops, i`ll take this if its still available, i`ll drop you a pm.
    yes will work on a 5, as James says its involving to fit but a worthy upgrade if your doing some work on the engine anyway.
    pm's replied to
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Make sure if you are running an over sizes inter cooler it doesn't rub through.
    SOLD
    And got yet another for sale, same deal
    cheers
    Ben
    Oct 2004
    Somerset
    Quote Originally Posted by Coops View Post
    cheers
    Ben
    Talk to me ben...07790069063..
    txt you matty lad
