Results 1 to 3 of 3
    Aug 2013
    Re-wiring fan with switch & relay
    It looks like that they guy who fitted a manual switch for the fan has removed the fan relay wiring which connects to the fan and temp sensor.
    Is there a guide to re wire the temp sensor with a relay connected to the fan and a override switch?
    Member Thundercat's Avatar
    Re: Re-wiring fan with switch & relay
    Can't understand why fan had be connected like that, i fitted a fresh fan loom when it was restored.
    Maybe use Haynes wiring diags, get it back to standard and then splice in a switch, though it wont really need one if the cooling system is in good condition.
