Results 1 to 6 of 6
    Speedo
    Chaps, is there any way of getting the standard gt speedo to accurately work when not using the j series gear box? I'm using the NDO gearbox but pretty sure it doesn't have any suitable outputs for the speedo. Is there another method of using the gt sensor and maybe bolting something to a drive shaft for it to read from?
    Re: Speedo
    I believe you can weld a some rinvs to the d shaft and a bracket for the sensor and it should work scoff done something like this there was a link I think on my old f7pt thread I will have a look tomoz off to bed know knackered
    Re: Speedo
    Any joy James?
    Non-member SP33DY's Avatar
    Mar 2009
    North East
    Re: Speedo
    Matt put your engine in a clio 182 they take the pick up off the abs ring
    Re: Speedo
    Quote Originally Posted by SP33DY View Post
    Good idea steve. I'll treat yours to some real power!
