Results 1 to 20 of 20
    East Midlands Area Rep Kingscott's Avatar
    Apr 2012
    Brake servo overhaul, anyone done one?
    Hi everyone.
    So after removing my car from my brake servo.....
    I have come to look for a replacement, gt turbo spares have new for a shocking 475 quid and an overhaul kit for 85 quid.
    I would rather not (due to the work involved in removing it) put a unknown second hand unit in its place so I think I will got for the kit.
    My question is: has anyone done a servo overhaul? I thought the units were sealed?
    Does anyone know of a cheaper new replacement like off a AX gt or whatever?
    Any pointers would be great.
    Cheers
    Adam
    Apr 2012
    Re: Brake servo overhaul, anyone done one?
    Just to add to the details, I'm having pedal issues doing strange stuff and feeling like pudding, I have hi spec 4 pots on the front and standard ms, rear brakes are standard but I have a manual rear bias valve fitted. Manual bleeding and bleeding using an easy bleed kit with still no joy. Ms is new, calipers are new.
    Cheers
    Oct 2012
    A
    I'd be looking at my options mate.
    1. Buy a new one for £475
    2. Buy a donor car for £500-£600
    2. Attempt to retro fit a clio servo to it (this is what I'd do)
    You can buy a clio servo for about £50-£60.
    Are you 100% certain it's the servo? What about the master cylinder?
    Apr 2012
    Hi mate
    Yer when the problem first happened the first thing I changed was the master cylinder, so it's new. The Symptoms stayed the same.
    However looking into the subject all over the net, I think the 172 cup servo and master cylinder will fit straight on. I think they have a larger internal bore size that will also help with the bigger capacity on the front calipers. Not that I had any issues before but whilst it's in bit I may as well upgrade. I hope I'm right and one will fit.
    The servo is literally the only thing I haven't replaced. I'm getting pissed off with it all now, it's been going on for months and months.
    Dublin/Ireland
    I've always found bleeding the 5's brakes hit and miss so I bought a sealey pressure bleeder and I got good hard brakes first time http://www.ebay.co.uk/itm/Pressure-B...item2a36c4ad76 , the one I got is a cheaper as its fed from a tyre!
    Mar 2010
    Blackburn
    Hi i have 4 pots on mine and standards calipers on the rear with 300 mm discs all round i ended up using a bigger mc to move the extra fluid for the bigger front brakes think its a 24 mm mc as apose to the gtt 19mm one. It seemed to have a much more positive pedal feel and stops amazing now could get the part number for the bigger mc if you want to try it.
    Apr 2012
    Quote Originally Posted by mk5gtt View Post
    Yes please mate, sounds good.
    Apr 2012
    Do you use the standard size servo?
    Mar 2010
    Blackburn
    Hi yes standard servo from original it has done 116,00 miles and still going .i am going to be putting a pedal box in when i do the rear engine converstion i will get the part number for you tomorrow
    Oct 2012
    A
    Quote Originally Posted by Kingscott View Post
    Hi mate
    Yeah I'd try a clio one matey. It shouldn't be too much difference.
    Apr 2012
    Thanks mate
    Apr 2012
    I have been offered a servo and master cylinder from a local renault specialist breakers off a clio 172 cup for 30 quid.
    Might be an option but would rather a new master cylinder for the sake of the cost and the work involved.
    Feb 2009
    Walsall
    Whats thats 24mm MC you used mate? :-)
    Mar 2010
    Blackburn
    Hi got the part numbers LM21007 is a delphi one bore is 23.8 mm and is roughly £49 at trade and the same one in brake engneering is MC4171 BE and is £51 at trade they come off a belingo vans and a few other french cars hope this helps out.
    Apr 2012
    Huge thanks mate
    Any chance of the company details for the clio servo and ms mate?
    Apr 2012
    http://renparts.co.uk/
    I can confirm that a clio 172 non abs vaccume servo does fit a renault 5 turbo, it's just very tight
    The master cylinder is ok, but two of the brake line fittings are M12 and not the normal M10 in size.
    cheers
    Apr 2012
    Brakes now sorted,
    thanks for the input guys.
    Feb 2009
    Walsall
    Cheers fella might invest whilst cars in bits and fitting brembos
    Feb 2009
    Walsall
    Will this one fit???
    Not the same part number as above but looks similar
    http://www.ebay.co.uk/itm/360819219696
