Results 1 to 8 of 8
    Mar 2013
    1.0mm a/c jet
    anyone have a 1.0mm a/c jet
    Non-member Jonny5's Avatar
    Sleaford
    Re: 1.0mm a/c jet
    Just drill out a 0.9
    Mar 2013
    Re: 1.0mm a/c jet
    ive had a 0.9 in it and runs rich ?
    Sleaford
    Re: 1.0mm a/c jet
    Quote Originally Posted by KEV 5 GT View Post
    Its an air jet, buy opening it up slightly you are letting in more air not fuel.
    More air should lean things off a touch.
    All done on a very slight scale if you're going 0.9 to 1.0mm tho
    Mar 2013
    Re: 1.0mm a/c jet
    carb setup at present is all stock jets apart from 2nd stage drilled to 1.3mm and afrs are flat out in 4th gear are 12.9
    Sleaford
    Re: 1.0mm a/c jet
    You said you tried a 0.9mm and it was too rich so id drill it out to 1.0mm try it, still too rich, do it to 1.1mm.
    I wouldnt go bigger than 1.3mm on the 2nd stage tho.
    Suck it an see.
    Mar 2013
    Re: 1.0mm a/c jet
    ok i will give that a try what the best afrs to be at ?
    Sleaford
    Re: 1.0mm a/c jet
    Everyone will tell you different mate.
    High 11s low 12s @ WOT seems most accepted.
    https://www.rtoc.org/boards/showthread.php?t=460
