Results 1 to 3 of 3
    Member clee's Avatar
    Derbyshire
    Facet style solid state fuel pump
    I've bought one of these to replace the front lifter pump on the GTA .
    Will it be OK used in an injection system ?It's pressure and flow rate are above the std Ren rotary unit .
    Oxfordshire
    Re: Facet style solid state fuel pump
    Quote Originally Posted by clee View Post
    they're bloody noisy, I know that. As long as it has more flow than your injectors you'll be fine.
    Derbyshire
    I'm going to put some 330cc injectors in .The front pump is 130l/hr 5-7 psi , feeds to a little tank/swirl pot then I've got a Walbro 255l feeding the injectors .
    Std setup is only 15l/hr front .45 to .55 bar and 130l/hr @3 bar rear .
