Results 1 to 11 of 11
    Nov 2011
    Gt Turbo Pipe/Hose fitment
    The engine has just been swapped on my Gt Turbo.
    New engine installed and running but a couple of pipes not connected. Could someone advise where these go to as cant find anywhere for them
    First one is the braided one coming from below the carb.
    2nd is the long thin pipe heading towards the strut top
    Thanks in advance
    Nov 2008
    Croydon
    Re: Gt Turbo Pipe/Hose fitment
    Any further detail of what they are connected to at the other end? Got any pictures?
    At a guess, the first one looks like it could be the aei line if it connects to the port on the carb below the throttle. Second one is probably the fuel vent if it's connected to the enrichment block on the carb.
    Nov 2011
    Cheers for the reply. Only got a pic of the braided one
    Nov 2011
    And another pic
    Nov 2008
    Croydon
    Yep, that's the aei reference pipe. You'll need a longer piece of vac hose to make it reach
    Nov 2008
    Croydon
    Quote Originally Posted by Nunnsy View Post
    Is the hose in the centre of this pic the other end of the longer hose in question??
    It's the hose connected to the sticky out thingy to the left and up a bit from the other braided hose in query.
    That thin black hose just needs to be fed down the back of the engine. It's a fuel overflow for when one of the things in the carb blocks/perishes and just vents to atmosphere.
    Member Tim B's Avatar
    Aylesbury
    Looks like the aei reference pipe. There is a good pic of mine T ed in on my profile engine pic's
    Aylesbury
    or if you mean the black one that goes down, that's the carb vent. just vents to atmosphere
    To avoid the confusion just created. The black pipe is the one that vents to the atmosphere, the braided one appears to the AEI reference.
    Nov 2011
    Thanks everyone - appreciated
