Results 1 to 15 of 15
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Micky Ping Pong turbos
    I'm tempted
    I'm really tempted.
    I've just been looking at this Micky Ping Pong T28 on eBay:
    http://www.ebay.co.uk/itm/T25-T28-TU...item5d303dc10e
    £179 delivered
    I've heard some real bad stuff about the build quality of Chinese blowers but, if it'd last say 4,000 miles then I'd be happy enough.
    I've got some questions though.
    1) Would it bolt up directly to my manifold and standard turbo elbow?
    I'm 99% certain that my oil feed would be wrong.
    2)I've got a garret t28 from my old S14a that may or may not have a buggered oil seal. Could I swap the core from the eBay blower into it and would there be any benefit in doing this?
    3) with low comp pistons, fmic, europarts cam and a 2 1/4" exhaust I should see 200 ponies shouldn't I?
    Thanks
    Oxfordshire
    Re: Micky Ping Pong turbos
    my 2P
    Ebay isn't a make, no traceability, no quality control. There is no reason why China can't make perfect turbos, but without those 3 things there is no reason why they should. It also means that if you buy the same turbo from the same supplier as your mate you may not get the same results.
    Some folks have had reasonable results, others have failed.
    That isn't a Garrett, so it's unlikely your Garrett housings will fit.
    The 'spec' is a bit made up, but reading between the lines it's claimed to be a copy of a GTiR turbo. Don't count on that. If it is, it's the type of thing that would work on a 172 up to maybe 300hp. It'd want a shot of NOS to be suitable for a C1J.
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    I'd spend real money on a real blower
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    What turbo would you guys recommend then?
    With the spec of my engine (above) what would I need to get around the 200bhp/200lbft for 20psi or less? It's going to be a road car rather than used for quarter miles so lag has to be minimal.
    Thanks
    Ross
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    You'd also have to rotate one of the housings for C1J fitment, which would mean re-tapping (if there's sufficient metal present) the comp' housing for the actuator bracket.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Yeah I saw that mart but thought I could mount it on the rear of the housing where you undo the bolts to rotate it
    May 1996
    Pie & mash shop
    Looks like the comp' housing is circlip'd to the chra, a la o.e T2.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Looks like I'll be giving that a miss then
    Thanks mart.
    Any suggestions for a good turbo?
    May 1996
    Pie & mash shop
    The lower c/r won't help matters, plus coupled with a larger blower will naturally dictate there being a 'delay' in spool/lag present.
    The 200sx blower you've got will probably be ok, assuming it's got a <.49 hotside fitted?
    Would cost next to nothing to replace that oil seal, or you could completely overhaul it altogether:
    http://www.ebay.co.uk/itm/Turbo-Rebu...item5adec29f80
    Edit: That kit is the first one I found on Google/Ebay - You might be able to find better/cheaper kits.
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    I always thought it was impossible to rebuild the gt28 core.
    Might have to get in touch with Bernie's blowers and see what they can do for me then.
    Member robw's Avatar
    Only if it's a roller bearing, journal types ones are repairable.
    Oxfordshire
    I'd go smaller on the turbo than that, T2/25 maybe? 200 is just a number. But I guess that depends upon how much overlap the EP cam has. Never measured one, so you're on your own there.
    Oxfordshire
    check out the quality:
    When you look at the picture of the turbine face that you'd bolt your elbow to compare the position of the 5 bolt holes to the shape of the casting.
    When you look at the compressor outlet flange compare the location of the centre hole to the outside of the casting.
    Both look well out of position.
    May 1996
    Pie & mash shop
    What d'you expect for a ton 80?
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    What's your thoughts on this one?
    http://www.ebay.co.uk/itm/2613322201...84.m1438.l2649
    From what I can decipher, the comp housing is the same as used on the 'low pressure turbo' Saab 9000s
