Results 1 to 7 of 7
    Non-member Coops's Avatar
    Remaing 182 Parts - Loads of bits left
    from the 182 I broke recently
    75k car, all parts on this mileage and undamaged/fully working unless otherwise stated
    prices are all collected and minus fees, but all ono and open to offers and deals on multiple purchases
    prices first, pictures after in same order
    cheers
    Ben
    - headlight stalk £8
    - wipers stalk £8
    - Starter £30
    - Earth Strap £3
    - Fag lighter £3
    - Drivers xenon washer jet £10
    - Passenger fog light £10
    - Radiator with fan assembly £20
    - Isofix bar £10
    - Fuel sender and pump £20
    - FBW Throttle body £25
    - Inlet manifold (silver, no TB or Coil included) £20
    - Fuel rail guard £15
    - Climate control panel £15
    - Top Dash £25
    - Airbox, no pipework, standard filter £25
    - Air con rad £20
    - Stereo control £5
    - Steering column shroud £15
    - Lower RS bumper grill £20
    - Air con pump £25
    - Standard Stereo (with code) £25
    - Pair door rub strips in BG £30
    - Rear badge, carbon wrapped £10
    - Boot handle in BG £10
    - Dogbone mount £15
    - Hazard panel £8
    - Drivers airbag £10
    - Dash insert set (silver) £15
    - Steering wheel insert (silver) £10
    - Boot lock mechanism £20
    - Bonnet catch, both sides £20
    - Passenger rear rub strip in BG £10
    - Aerial with wire £6
    - Parcel Shelf £10
    - shield £7
    - RS sill trims, pair in BG £25
    - Some random thing with tubes, lol! £5
    - Rear lights, pair £25
    - Interior handles, pair £20
    - Interior pulls with windows switches, pair £20
    - Door trims, pair £5
    - Front speaker grills, pair £6
    - Engine cover, small worn groove in rear, not noticeable £20
    - Interior wing mirror trim covers, set £8
    - Front badge, painted badly in black £5
    - Lower gearbox mount plate and rubber £15
    - Inlets, painted black, pair £35
    - Power steering rack, pipes and res £50
    - another shield £5
    - Calipers + hoses, pair, no carriers £20
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    [/URL]
    Apr 2011
    Netherlands
    Re: Remaing 182 Parts - Loads of bits left
    Steering wheel sold? Anddo you have the cc switch/panel?
    Non-member Chunk's Avatar
    Oct 2010
    Loughborough
    You think the Aerial would fit a mk1?
    no reason aerial couldn't be made to Kiz?
    and no wheel, i'm keeping it for mine and unfortunately the CC panel has had immobiliser key received fitted to it so not mint
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Does the stereo have Bluetooth?
    Non-member Ricardo's Avatar
    Ben, do you have the heater resistor still? Pretty sure that's what it's called, it's located in the drivers side scuttle area.
    Cheers
    Doubt the stereo had fail tooth, its just a bogo Renault one??
    Ric, fraid not mate, one of the first bits the vultures descended on after the RS192!!lol!
