Results 1 to 15 of 15
    May 2012
    Naughty Car
    Hi there, doing my head in:
    Symptoms are as follows,
    Cutting out,
    Idling at 500rpm,
    15 on afr at idle,
    When it goes, off throttle the afr leans off to 20!
    Lumpy.
    Basically being very very naughty, any suggestions?
    I would really appreciate your input - before I spaff money on a new carb from GT spares.
    Oh, turbo is a GT28, ktec tubular manifold which cracked and was repaired, big jim down pipe and AFR gauge which has been calibrated properly.
    Thanks.
    Member robw's Avatar
    Re: Naughty Car
    Have you adjusted the idle screw and mixture screw?
    Oct 2003
    Re: Naughty Car
    Is the idle/mixture screw even there?
    May 2012
    Re: Naughty Car
    Not touched, not even sure I have one? Before the crack in the manifold it ran like a dream! I obviously took carb off to do work on manifold.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Naughty Car
    Cleaned out the idle jet?
    Dublin/Ireland
    Re: Naughty Car
    restrictor on breather pipe....replaced?
    May 2012
    Re: Naughty Car
    Which breather pipe?
    I've not done anything with the jets, I was planning on getting car set up by Bogg brothers, east Lutton. But they are not interested anymore!
    I'm wondering if the carb is buggered. It's so annoying, it needs constant attention. Worse than the wife!
    Re: Naughty Car
    They're annoying! Have you cleaned it out?
    Dublin/Ireland
    Re: Naughty Car
    have a good read.... https://www.rtoc.org/boards/showthread.php?t=27381 somewhere in there u can see the idle jet.....easy to clean
    Feb 2009
    Walsall
    Re: Naughty Car
    Idle jet blocked? Take it out give it a good clean.. Had similar problems before with mine
    Non-member gtmatt's Avatar
    manchester,sale
    Re: Naughty Car
    Quote Originally Posted by w35ty View Post
    Me to bought a new one in the end that did the trick
    May 2012
    Re: Naughty Car
    Thanks guys, I have not touched the carb. Perhaps my next job....
    Re: Naughty Car
    Did you replace carb base gaskets and inlet/exhaust manifold gasket? Possibly an air leak.
    May 2012
    Re: Naughty Car
    Carb base gasket no, but yes to inlet/outlet gasket.
    It's a very naughty car.
    Grrrrr
    Re: Naughty Car
    Change the carb base gasket if you have took the carb off..also check one way valves and pipes on inlet
