Results 1 to 2 of 2
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Horn and Rad Fan failure.
    I have a horn and fan issue.
    I can hear the relays clicking.
    No action from the horn , or coincidentally the rad fan. I have it on thermostat activation and manual overide as well.
    I know the fan works as I have bridged the connectors from and to the battery.
    Same as for the horn.
    The relay is a little wierd with a huge voltage drop on the one that goes to the horn. Are the two related ? IE horn + rad relays ?
    I have checked the earthing point at the driver side headlight.
    Any ideas ?
    Oct 2009
    Doncaster
    Re: Horn and Rad Fan failure.
    I have ...
    Two failed relays.
    Changed the AEI one to the horn, HONK
    Swapped it to the relay point for the rad fan WHIRRRR
    Ill have a looksie on ebay / rtoc for two new relays
