Results 1 to 4 of 4
    Apr 2013
    Dublin
    Door Hinge pins stuck- help!
    Phase 2 Single door hinge pins - old type are stuck I've tried everything and can't shift them
    Any ideas welcome -
    Drilling seems to be my only option
    Non-member Wallace's Avatar
    herts
    Re: Door Hinge pins stuck- help!
    I've yet to do mine
    But if you haven't already? - I'd try running a small drill through the centre of the pin in case there's crude stopping it from compressing, and then a shiiiiiite load of wd40 and some grips to try and get themfree.
    Take it you've got hinge remover tool? - otherwise one of these
    Hope this may be of some help
    Non-member dj_craig_'s Avatar
    May 2010
    Support door with a block of wood along bottom edge and jack up untill door is straight before hammering
    Oct 2012
    A
    Mine were a nightmare- we acetylened the door hinge to getine out, came out like a piece of cake
