Hi, just wondering who the go to man is for injection? Ideally I'd like a quote on a full conversion installed with parts supplied...
My first choice would be Chirs, aka Scoff. - http://www.efi-parts.co.uk/
Also michael tinery for the manifol. Amazing piece of kit
Sweet, thanks guys.
For those who did the bolt on stuff themselves, how difficult is it? Sorry, I haven't checked to see if there was a thread dedicated to it. Will check now...
as above scoff for ecu and mapping. michael for manifold.
not to bad to install your self just need a few brackets making up for fuel pressure reg and coil pack. a new relay and 4 way fuse block for fuel pump and to fuse the ecu coil pack throttle posistion sensor and injectors is needed. sounds a lot but it can be connected straight into the existing fuel pump relay socket useing spade connectors. this makes instaling so easy as you can also connect to the tacho at this point aswell.
list for starters is
ecu
manifold
fuel pipe
fuel pressure reg
t pices for fuel lines
injectors bosh red 440's
coil pack
relay
fuse holder 4 way
wire.
uprated fuel pump
Ive no fitted it all yet. Still to get a ecu from scoff. Got everything else tho. Cant wait to get the conversion on. Totlay have a different motor. The mechanical parts no bother but electrical side not my thing . However scoff gives u plenty help n makes it sound easy. Someone who has done the conversio. Should well stick advice pros cons ect of how easy hard and what the differance was
later this week i plan to post a giude up along with some drawings and pics to help people out. just need to finish it off
I'm feeling up for the challenge. I guess it would make sense to get all the bits together first then spend a weekend carrying out the conversion...
Second what alot are saying about the guide i will hopefully be efi ing mine at the end of the month would be good to see the process and tips
here is part one. got to finish part 2 and add some more pics. any comments welcome
https://www.rtoc.org/files/?path=Technical Files/Adding EFI to a gt turbo./
I think the link is broken royz.
just click on the files tab at the top then on the left hand side search for ROYZ and it will be the top file
Think this is the direct link to the file
https://www.rtoc.org/files/Technical%...20yourself.doc
Cheers Logg.
cheers logg.
my computer dose funny things when copying links somtimes.
Excelant write up for part one. Cetianly helps alot. Keep up the good work
good work Royz,,,, keep it coming!
Nicely done royz.
cheers matt. ment to put fuel pipe clips. ill update it in the next few days.
photos of the second sensor set up have now been uploaded
now added part 2 which covers the testing and checking of things. dose not seam a lot there but if you do go down that route and can see the things on a screen in front of you it will become clear. i have also added some things to part 1 which i missed out
ill will also be uploading some of the diagrams i collected in the next week just got to scan them and put all together.
[QUOTE=royz;342569]now added part 2 which covers the testing and checking of things. dose not seam a lot there but if you do go down that route and can see the things on a screen in front of you it will become clear. i have also added some things to part 1 which i missed out
ill will also be uploading some of the diagrams i collected in the next week just got to scan them and put all together.[/QUOTe
I carnt open the linns as it says there incomplete, i hate computers!!!
just below the rtoc baner at the top of the page click on files then on the technical section there in there somwhere. the links proberly wont work now as i have updated the files. oops
