Results 1 to 10 of 10
    Non-member GaryS's Avatar
    Fleet, Hampshire
    Adaptronic 420d
    Hello, my car dont run to good. The ecu has lights 4 for the injectors and 4 for the ignition, but no 4 on the ignition does not flash i cant see anything wrong, whats up with it?
    Fleet, Hampshire
    Re: Adaptronic 420d
    Basically it running really crap and hunting all the time, tries to conk out when u move.
    Think my first post is just meaning less cr@p
    No pod for me
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Adaptronic 420d
    Only 3 Ignition lights should flash. You're useing Ignition 1 and 2 for the wasted spark and Ignition 3 is driving the tachometer. Ignition 4 is not connected
    "Don't run too good" probably means it is not mapped yet ?
    Fleet, Hampshire
    Re: Adaptronic 420d
    Im using that map you sent me? i thought it should at least run ok?
    Fleet, Hampshire
    Re: Adaptronic 420d
    It hunts away like a gooden
    Sep 2009
    meath
    Re: Adaptronic 420d
    i hope i'm not out of line scoff, the map that was sent is a base map its not 100% right, because every car is different and needs different fueling
    Fleet, Hampshire
    Re: Adaptronic 420d
    thats fair play, i just thought it might run abit better
    Non-member Blocky's Avatar
    Jun 2012
    Re: Adaptronic 420d
    Quote Originally Posted by GaryS View Post
    In the hope that you might just get away without having to map it correctly
    Non-member 5teve L's Avatar
    RH12
    Re: Adaptronic 420d
    Idle control valve ???
    Re: Adaptronic 420d
    Air leak?
    A base map is exactly that something to work from. If it starts and runs the the base map has fulfilled its duty.
