Results 1 to 7 of 7
    Non-member gttjames's Avatar
    Cambridge
    worrying noise? video of engine
    Since rebuilding my engine its done about 600miles, flushed with oil when building, and after run up dumped oil, then changed oil again at like 300miles. But I have since noticed a noise. I never really paid any attention before the rebuild, but since rebuilding you kind of listen for things a lot more.
    Its a kind of echo, like a hollow object being tapped slightly, noticeable on idle as the video shows, doesn't get louder when revved, seems to go. Sometimes I think its from the water pump the rest of the time it just sounds from all over. Am I being anal or do I have a problem
    http://www.youtube.com/watch?v=bb43G9pYVg8
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Re: worrying noise? video of engine
    That hollow noise that's comes and goes is concerning.
    have you had the belt off and checked the water pump for play?
    Probably best you wip off the rocker cover aswell see if anything obvious can be seen
    Mar 2010
    Blackburn
    Hi that hollow sounding noise sounds the same on mine turned out out to be bent pushrods tapping the head every now and again got new sleeved ones of sid dawn on here problem sorted it .
    Oct 2012
    A
    Maybe take the alternator belt off for a minute to eliminate bearings in the water pump and alternator.
    Marky mark would be the man you want to ask- he's very knowledgable
    Kent
    To be fair, those tappets sound a bit noisy... Might want to adjust them, also as above check the pushrods for true, roll them over a sheet of glass and see if some are bent.
    Cambridge
    cheers guys, yer il whip alt belt off first and run up, if not il take pushrods out and check them, then if not il just re do the valve clearances and see where I am. I will report back lol
    Mines allways been tappy. What would people recommend for piper 270 cam? piper say 0.25inlet and 0.30 exhaust
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Don't people normaly just do 20 20?
