Results 1 to 6 of 6
    Jul 2013
    very little oil flow through oil feed
    i seem to have very low amount of oil passing through my oil feed to turbo but engine and oil pressure and gauge are reading fine, could this be a blockage? i have taken of the oil feed and even run the car and i get a dribble so im guessing its the stem on the oil pressure feed?
    Re: very little oil flow through oil feed
    There is a non return valve under the turbo oil feed, it looks like an inch long nut. Check that isnt stuck/filled with ****e etc.
    Are you using the standard oil pressure gauge or aftermarket? The original gauge is very unreliable.
    Jul 2013
    ok nice one i will give it a check, i am using a auto gauge not the o.e, cheers brigsy
    Feb 2009
    Walsall
    Is your gauge plumbed in just before going to turbo? After the or one way valve like, aint got a filter on there too have you?
    Banned
    Apr 2012
    If it's old it's probably filled with carbon deposits. Some of the old turbo feeds i've cut into after replacing have been shocking. Buy a new one.
    Jul 2013
    Std oil feed system using after market gauge off of original feed/sensor
