Results 1 to 7 of 7
    Nov 2008
    west midlands
    Adjustable Fuel Pressure Reg ??
    Anyone recommend a good fuel reg and gauge please ??? need it urgent !! Need to reduce pressure ( at least that's what I think is the problem ) flooding all the time , needle jet cleaned etc , still dripping when pump running at full speed. Antony
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Adjustable Fuel Pressure Reg ??
    dripping from where? when was carb last serviced? sure a gasket in the carb hasnt split?
    Nov 2008
    west midlands
    Dripping down venturi , was getting a bigger return fitted to tank ( guy let me down big time !! ) carb rebuilt by Sparkie last year , problem only started a short while ago , cant figure it out . nothing new or different on the car ?? car runs fine when return goes to a can rather than the tank , same fuel pump ( no pressure gauge )
    This isnt in a campus is it as they have a smaller return?
    Nov 2008
    west midlands
    No running Fuego Turbo motor in my R17ts , have reduced the power to the fuel pump which has stopped the dipping , so just need to sort a good adjustable reg and gauge to do a proper fix
    I should really read profiles firstband check car specs
    Nov 2008
    west midlands
    Can anyone recommend a Fuel pressure reg , suitable for the 32DIS please , need to get one . Cheers Antony
