Results 1 to 22 of 22
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Has anyone thought of bike carbs?
    Just something I was pondering at work last night,
    Surely there's a limit to how far you can go with the solex 32 and without wanting to go as far as injection what other options are there?
    I've got a set of r1 carbs which I bought for a project many moons ago and I've recently been looking into what needs changing to use them in a force fed application. It seems that there's not much.
    Here's a guide I found:
    http://www.turbo-bike.com/Pressurize...etor%20R1.html
    Obviously space is an issue on a c1j head. The likes of 'Bogg Brothers' could make up a short inlet manifold but I'm sure you'd still have to cut into the battery tray / washer bottle area for a plenum chamber.
    It's all just ramblings at the moment and not something I'd seriously consider unless I was looking for stupid amounts of power, but I'm just interested to know if anyone has already done it?
    Aug 2004
    Re: Has anyone thought of bike carbs?
    Think Matt@codered has thought about this, or Ollie Davies has thought/made it... Not sure if he uses it
    Kent
    The carbs worked out to be a bit of a pain in the arse, c1j wise anyway.
    F7P/R isn't too much of a headache if using bike throttle bodies (not carbs), we found out if you used hayabusa throttle bodies, we could use pico injectors in the bike bodies, or obviously retain the injector holes in the head.
    Non-member Fordy's Avatar
    Aug 2010
    Cambridgeshire
    Not sure what's involved but I recently been playing with zetecs on hayabusa throttle body's and all I can think about its making some sort of ally plenum chamber and mounting them on a 5 to see what would happen
    Kent
    Here's a few I made a while ago.
    Kent
    Too much hassle for little reward? From what i have read they are a carry on to set up on boosted applications.
    If i were to go individual throttle per cyl i would use throttle bodies and efi. The question is would a throttle per cyl make any difference for hp compared to one decent sized throttle body.
    Kent
    Blown carbs, yes. Way too much hassle.
    R5turbo 2 used individual throttle butterflies?
    Kent
    Cheeky last one, alfa 75 engine in GTAm. This one is busa throttle bodies, with spacers fitted straight onto the original inlet!
    Non-member allanr5gtt's Avatar
    Dec 2008
    the carport
    What's the pro and cons of having throttle bodies on f4r? Does it make noticeable difference in bhp or torque?
    Kent
    It did to mine and definitely did to penfolds red 16v car.
    More pros than cons.....
    Aug 2004
    Love my conversion, goes nicely, very easy to drive, yet to test it fully out on track or open road but reckon it will do very well .
    Dec 2008
    the carport
    What's the cost of itb's? can the std 172 ecu be mapped or is stand alone needed?
    Kent
    Itbs are expensive.....but there is a way to use standard ecu on itbs.
    For example, there is a full itb setup, second hand, going on clio sport for £1900.
    Dec 2008
    the carport
    To much to for me then. I can always dream lol
    I 'think' the t2 setup is metering head & the like, mfi injection similar to rs turbo's. Iirc pulsar gtir has tb's per cyl. Jenvey done a tb kit for the gtt, big ££.
    They are a worthy mod on an n/a engine though.
    Tipton
    correct.
    the turbo 2 inlet tract goes like this.....
    air filter - metering flap - throttle body - turbo - intercooler - engine.
    thats a single throttle body btw.
    Kent
    Of course.... Early fuel injection
    Banned
    Apr 2012
    I'm doing a conversion on the 21.
    Sense seemed to suggest using FI ITB's in the first place so I picked up some SR20DET ones from a GTiR. Bore pitch is almost identical....how convenient!
    Dec 2008
    the carport
    if I wanted to build my own diy throttle bodies kit on f4r engine what would I need?
    1. throttle bodies (from a hayabusa)
    2. adapter plate from tb's to head (custom made)
    3. air filter and adapter plate
    4. mapping
    5. some sort of breather mods?
    just a idea at the moment maybe something over the winter
    Non-member SCHWARTZ's Avatar
    Wallington south london
    correct.
    Was this to help against lag sparkie?
    Have read somewhere that a tb before turbo allows turbo to keep spinning in a sort of vaccuum when the throttle gets closed rapidly. Maybe something to try
    Non-member olidaviesuk's Avatar
    Nov 2008
    Bromley
    80s f1 turbos and a lot of the wrc cars use this - you need a throttle butterfly in the inlet plenum too. One has to open fractionally before the other, very tricky to get to work properly without fly by wire throttle... VERY effective when it works tho...
