Results 1 to 22 of 22
    Dec 2011
    Removing EFi
    Laugh all you want but needs must!
    I have a R5 which has been converted to EFi. If I wanted to return this back to running on carb/AEI, what is required?
    I just wanted a list of everything in one place. Oh and I maybe looking to convert back too!!!
    Non-member TNT ANDY's Avatar
    Re: Removing EFi
    Quote Originally Posted by Romil Davda View Post
    Whatcha doing you crazy fool.
    Member Thundercat's Avatar
    Re: Removing EFi
    Romil get that car on the road with the Efi fitted. Best mod you'll ever have on a c1j.
    Dartford
    Re: Removing EFi
    WHY?????
    Dec 2011
    Re: Removing EFi
    I really want to get the blue Skeete 5 I have on the road.
    The quickest and cheapest way is removing the EFI. It only has a base map and only idles.
    I have loads of bits and bobs and I think its silly to throw more money at it just now.
    I want to take this car to Sangliers 2014 on EFI, so depending on the whats needed, I might just wait and save the pennies (well pounds) for the mapping!
    Dartford
    Re: Removing EFi
    What ecu is it running?
    Re: Removing EFi
    Romil - drive mine at Blyton, see what you think before ditching it.
    Dec 2011
    Re: Removing EFi
    MBE 970 to be precise! I have the software on my laptop, also available online.
    Dec 2011
    Re: Removing EFi
    Knowing my luck, i'll break it!
    Dartford
    Re: Removing EFi
    Tbh unless you've got all the bits needed to put it back to standard setup then you'll spend the £300 you could of spent getting it mapped...
    Y not have ago yourself? I've got some cj1 maps you can look at/use for reference? You need to make a home made stethoscope, afr and a passenger.. Run safe ignition at first, sort the fueling at low boost then once that's done your laughing..
    Does it har a self learn mode like the adaptronic?
    Dec 2004
    Aylesbury
    Re: Removing EFi
    Romil if you need hand mapping I could help out, I need to learn too so be good for both of us.
    I got Bonnie started today but does need map looking at as opening throttle does create a big flat spot
    As has been mentioned you could spend as much on converting it back as it would to map it up
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    Re: Removing EFi
    I
    Dont be ****ing stupid.
    It going to cost you to take it off , and then put it back on again.
    Step away from the five with the EFi.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Re: Removing EFi
    That will be the transient settings/accelerator enrichment depending on ecu mine still foes this
    Romil don't be silly just get it mapped or do it your self don't convert back.
    Re: Removing EFi
    Keep it efi mate. No doubt a fair few bits will have been modified to fit it. Get it mapped and job done
    Feb 2009
    Walsall
    Re: Removing EFi
    Efi all the way! Id like to go efi to be honest just money if you wanna swap though il snatch it
    Non-member Logg's Avatar
    Re: Removing EFi
    Unless you built the set up yourself mate who knows what they changed on the car.
    As everyone else have said just get the car mapped mate I'm sure a little bit off boost mapping can be done DIY style to make sure the lumps ok.
    After having efi for almost a year id never go back to a carb.
    Dec 2011
    Re: Removing EFi
    Thanks for the responses guys...
    Staying EFi and I'll get get it mapped year next year.
    Non-member Ricardo's Avatar
    Re: Removing EFi
    The worst ' I have EFI' thread ever
    Oct 2004
    Somerset
    Re: Removing EFi
    yeah... , that man bag is messin with your swede....
    Scotland Regional Rep youngscottie's Avatar
    stirling
    Re: Removing EFi
    Why would you want to remove efi
    That's like going back to washing in a river or ****ting in a bucket
    Get it mapped and enjoy the c1j at its best
    Non-member royz's Avatar
    stockport
    Re: Removing EFi
    Quote Originally Posted by Thundercat View Post
    can vouch for that. best thing i have ever done to mine.
    Re: Removing EFi
    Quote Originally Posted by jesus in the seat of a 5 View Post
