Results 1 to 5 of 5
    Jul 2009
    lost
    clio phase 1 jc5 gearbox
    im after a clio ph1 172 jc5 box for my f4r conversion. after a rebuilt or low mileage box.
    cheers
    Non-member alex barker's Avatar
    Jul 2006
    Re: clio phase 1 jc5 gearbox
    I've got better than that.
    Jb1 from a kangoo diesel. I can get you the rest of the code if wanted.
    Looks exceptionally clean for a renault box, also has shelf number sticker on so I assume its recently refurbed.
    £1000 for you ;-)
    Jun 2010
    sw london
    Quote Originally Posted by r5_scotty View Post
    cheers
    i have a clio 172 ph2 jc5 £150
    Jul 2006
    ^^^^ ph2 boxes ain't speedo drive unless from a cup.
    Non-member Pete@Backyard Racing's Avatar
    Nov 2008
    Manchester
    I've got a ph1 172 gearbox, no crunches or whines but started popping out of gear. Apparently just needs the nut on the end of the gears tightening up, (common fault)Or could have been a selector rod issue. £100
