Results 1 to 5 of 5
    Oct 2010
    Fox alloys offsets?
    Hey
    I'm running an almost standard R5 turbo lowered 30mm with standard brake discs.
    I was wondering what size of offset would fit properly without spacers. I plan to buy 15" fox 5 spokes alloy wheels from fox but struggling to understand the offset numbers.
    Is there anyone out there that can shed some light.
    Many thanks
    Jason (j4134)
    Non-member Gtturbo's Avatar
    Mar 2013
    Re: Fox alloys offsets?
    Hi matey, you need an offset around 35mm to 40mm pal.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Et36 is standard you can use wheels with a different offset but it can have funny affects on handling.
    Oct 2010
    Many thanks for the advice.
    Non-member bood's Avatar
    May 2011
    You would have to be careful if your changing the width of the wheel as the et is a measurement from the wheel center to the back face.
