Results 1 to 17 of 17
    May 2012
    Front mount intercooler
    Hi guys, what size front mount should I get? I know people buy generic ones, but I am not sure what size I should get - fancy one about the size of the Forge FMIC, quite happy to cut cross member.
    Want and will be keeping stock bumper, don't mind losing fogs.
    Thanks in anticipation.
    norwich
    Re: Front mount intercooler
    dont cut the cross member
    unless you intend on fitting or fabricating some type of plate to re attach afterwards ,as you will weaken the strength of the chasis no end
    as regards front mount, what boost you intending to run, what hp, and what size turbo? huge core areas,and boost runs will take more to fill, ie an almost standard t2 turbo wont do the system justice, the gt breadbin is a good comprimise on anything up to 18- psi on a t2 standardish unit, if youve got bigger and intend on running more boost/power then aim for as gooder core design as your money/budget can afford, as it will pay for itself in respect to performance per psi,
    dont run one myself,but loads of members do, and im sure most will put some imput towards whats hot and whats not
    Non-member TNT ANDY's Avatar
    Just a guide, a member on here is running 18 psi on track on a T25/t28 wi th a bread bin type of cooler. I've gone for a 2wd Cossie cooler and seen no more than 36 on the RR at 200bhp.
    Moderator Red October's Avatar
    Mar 2012
    Stoke on Shizzle
    Well me and blunty are running 2wd cossie fmics. Ford boys say theyre good for 300 and they fit underneath the crossmember with no chopping up. You can keep the oe bumper in tact without altering that either mate.
    You do run a charge cooler though don't you?
    Dartford
    I've got a 4x4 cossie cooler for sale. They are good for 450 ish hp. Pm me if interested
    norwich
    of course, only the best will do
    and before it all starts getting silly,with the pro and cons again. oily got 28c on the rollers with 285bhp so dont start, by the way booked in for rr on 31 /5 /of this year(yes you read it right, this year!!)
    if you fancy popping in for a looksy (its on the friday)
    norwich
    ps your turbine wheel and housing is too small, like something else thats very close to you and before you say , "how would you know" im on about no legs round the corner
    Non-member Logg's Avatar
    I use a 550mmx225x63mm ebay intercooler ACT's are 15 degrees above ambient temps at 24 psi.
    The cross member did need triming to fit but did just fit behind a oe bumper and was a very tight fit.
    May 2012
    Quote Originally Posted by Logg View Post
    Fantastic guys thanks, when I said "cut" the cross member I actually meant "trim" as per what you need to do to fit the forge item. Im running a T28 on tubular manifold and downpipe. Got an AFR, running 12-13s on boost, quite rich I reckon and fancy taking whitey down to Bogg Brothers at East Lutton for a tune up, once I have a FMIC fitted. Not had a chance to check boost levels, since I have only driven it from painters to my school.
    Im quite happy to make my pipe runs myself, I have a budget of £1000 for FMIC, interior, refurbing wheels and maybe a little tune up time, so where I can save money, I would like to.
    Got my interior cards packed up waiting to be shipped to Phoenix for flocking, fancy a pair of those cgb bucket seats.
    Your advice is greatly appreciated. Thanks.
    Non-member andybond's Avatar
    Oct 2009
    Doncaster
    12-13 isnt quite rich. 13 is lean.
    Wants to be 12.1 ish really max
    May 2012
    Oh, I though the higher the number the leaner it becomes, 22 is the calibration in the air.
    Thanks.
    when I said trim I ment cut but not all the way. Picture stolen from steve of the cut/trim that's needed.
    https://www.rtoc.org/boards/album.php...&pictureid=207
    As for AFR's I would aim for 11.5-12.0 on boost as that's nice and safe. Running close to 13 is asking for trouble if your lucky its headgasket popping territory if your unlucky cracked liner or hole in piston.
    Dec 2011
    I am goin to fit my forge intercooler soon the reason i like the off the shelf items are they look neat. But some people on here have made there own up and look brilliant have a search on here type in titles only front mount intercooler and theres a lad called raj with a white 5 and its got orange pipe work looks amazeing
    Dec 2011
    Yea just checked again its under "front mount intercooler pics" some for you to have a look at mate
    May 2012
    I will double check, when I boost!
    Would like the forge kit, but a little pricey, will be painting the cooler piano black, to match the wheels.
    Thanks
    norwich
    dark colours like black absorb radiant heat, which means the cooler will have to work harder , which inturn will give you higher inlet temps which in turn will lose you power, silver is the way foward on that one or a light colour if you must paint it
