Results 1 to 28 of 28
    burton on trent
    Would love to see some Renault power in drift
    As some of you may knowni took the plunge in buying a nissan drift car which is great fun, now at drift events I've seen just about every model of car there, but no renaults ever, it's a massive void that needs filling by any rtocer, what about a 21turbo quarto modified or even a rwd Renault 5,' lots of people use the volvos with the f7p block however these are always considered a basic low power car as people leave them stock, never seen a boosted one on the drift circuit, certainly turn some heads I think. Be really cool to see something new and fresh, I know renaults exel at more general circuit racing but it's just a though to try something new.
    Nothing would make me feel better than seeing a 100percent non Jdm home brew Renault ripping up the Tarmac. When you consider most drift cars are typically bolt on spec mods, and s14s on average sit at around 280bhp it wouldn't be difficult to make a French tin can have comparable power.
    Apr 2011
    Netherlands
    Re: Would love to see some Renault power in drift
    getting a renault engine to make power isn't the hardest part, trying to have it make those power reliable is a whole different story!
    drifting with a rwd rear engined short wheel based car would only result in 180's/360's.
    it isn't as suprisingly you won't see renaults as they are not rwd. atleast the majority of them....
    burton on trent
    Plenty of early starlets ( I know there rwd) mk1'fiestas and the like cropping up though, I always presumed as much with a short wheel base but a early start with a cosworth engine is smashing lots of events,'I imagine the setup is just much crucial. Just my chain of thoughts on an early morning,'random blurb
    The main problem is no cheap rwd renaults are available. Alpine gta, r5t2, clio v6 are all big money, nobody would risk smashing one up & parts are mega expensive. 21t quadras are as rare as rocking horse ****e. This is why everybody goes for 200sx or similar jap rwd as parts are available and cheap to tune?
    From what i read the transmission is pretty weak so any more power than a bog standard f7p/r and your asking for trouble?
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Brigsy are you on about the Volvo 340 rear mounted gearbox being weak? Even the 1.7 version? If so that's a shame as I had a plan
    Is the starlet a yellow kp62 with escort running gear and a n/a carbed yb lump?
    Non-member Logg's Avatar
    My mates 340 dealt with 200bhp+ happly enough the main issue was getting a clutch to fit as I remember they kept on slipping.
    Jon is right there's no affordable Renault option for drifting.
    Gary maybe we should implant the idea of turning up to drift what you brung into James's head.
    Classifieds Moderator
    Mar 2004
    I think my hi ace could do some drifting with a little boost, rwd grip is shocking..
    Logg I like that Idea but James upside down in a hedge is becoming a more common sight now days
    Was thinking b18ft 5 rwd using the Volvo running gear
    I had a Mitsubishi l200 2.5td and that could get very sideways easily.
    Poor old James
    Pretty sure my mate had to cut the throttle body off and weled it on the other side and also something similar to the exhaust manifold to fit the b18ft inthe 340.
    http://huskyracer.50megs.com/cgi-bin...dt%20side1.jpg
    http://huskyracer.50megs.com/cgi-bin...ld%20side1.jpg
    Mar 2004
    James was lucky to limp away, it's lucky we can even take the pi55 out of him.. There's a whole thread for mocking him, it's called his project thread..
    yeah he was lucky.
    That engine looks awesome but wasn't thinking of putting my b18ft in a 340, want the 340 running gear in my 5
    yeah he was lucky.
    You crazy man but id guess the same mods would be needed. plus major floor work.
    Jul 2009
    lost
    note .. . . . . . . . haz`s project???? b18ft van lol drifting beast hahahaha
    I was lucky and I don't mind the abuse reminds me not to drive like a dick some rwd drift sounds fun in a controlled and dedicated area not sure how good a rwd 5 would be at drifting going around in circles is prob more like it
    Yep from what i read they arent the best...the 360 stuff is better but not sure if that would work?
    I recall seeing a c1j converted one on retro rides, ill try and find the link later. Clutch a problem too
    Non-member GTphil's Avatar
    That is one twisted gtt please don't do that to the rwd one
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Theyre fantastic for drifting..... lol drifting without even knowing
    You gotta be joking I am scared enough about driving it in a straight line let alone drifiting it
    Non-member 5teve L's Avatar
    RH12
    Still makes me think 'roof chop'
    & I always wondered how the fook the sunroof is still intact
    Il have a look into 360's
    According to scoff it was a handfull in a straight line with just a 230hp c1j, do you know if there is much weight difference between a c1j and the vag lump?
    Mar 2004
    I can pick up a c1j if I awaken the hulk inside of me but a clio 1.8 16v was a struggle with 2.. I'm pretty sure the vag lumps twice as heavy as the c1j if not a touch more..
    Dec 2012
    Agree i think a five is too small to be a good drift car. I had a nice E34 M5 now that was effortless. 3.8 340bhp rwd.
    So considerably more weight over the rear wheels and I'm guessing the front end will be very light.........so that coupled with the short wheel base most definitely means circles as opposed to drifts opposite lock will soon have you facing the opposite direction
    I suppose it wasn't purchased for drifting, traction off the line should be quite fun however
    Looks like an awesome project, il have a proper read when I get to a computer and not a phone to see what he did tranny wise.
    Dec 2012
    Maybe wih a rwd 5. You should weigh all corners and add weight to the front to compensate.
