Hi all,
I want to adjust the acc pump slightly to increase fueling on part throttle! I have set it with a 5mm drill bit but afr's are a little lean.
Should I be loosening the nut or tightening it to increase the fueling?
Also, I'm at 500miles mark now running the engine in, but am nervous about giving it the FULL beans
How many miles do people recommend on newly built engines before they rag the **** out of it?
Haynes just talks 500 so am I good for full Santa pod type driving
