Results 1 to 34 of 34
    Non-member OUTLAW's Avatar
    ENGLAND
    Strange Rattle?
    can anyone please put there finger on this horrible, annoying rattle please. she made this noise since i have owned her. put a new turbo on yesterday, along with the cup mod, (thanks T-tim), and the rattle is still there. all the noise is coming from the turbo, but surley both turbos can`t be fecked. she is blowing a little where the turbo meets the immediate manifold (which i cannot eliminate completley, even with a s/s gasket) and a little at the downpipe ( going to try sort that in a bit) has anyone heard this rattle before
    http://www.youtube.com/watch?v=a0s7uSnUFz0 ...thanks
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Strange Rattle?
    that sounds like your manifold gasket is blowing on one exhaust port
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: Strange Rattle?
    I used to have a nasty rattle, it was from the old warm air feed pipe.
    I noticed another one yesterday too, checked eveything over, then it turned out to be a Dr.P can with a penny in it
    ENGLAND
    Re: Strange Rattle?
    pic of the old gasket, thanks again scoff.................
    Non-member Nick k's Avatar
    Leicester
    Re: Strange Rattle?
    Bet that was fun to change!!
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Re: Strange Rattle?
    Quote Originally Posted by Tarmac trasher - Nick View Post
    thats an easy job,just abit fiddly.
    didnt take him long to change it either
    ENGLAND
    Re: Strange Rattle?
    it was a lovley job......., once shes up on A stands. just finished putting her back together, (not run her yet) i am having problems fitting the oil feed (thread) as i changed the turbo at the same time,.... off to try and get some kind of adaptor,
    Non-member gttjames's Avatar
    Cambridge
    Re: Strange Rattle?
    just tried watching it and got 'video has been removed by the user'
    does it sound like this?
    http://uk.youtube.com/watch?v=al_CmO...e=channel_page
    i just took the engine/box out and fitted a new clutch, fuel pump, silicone hose and clutch cable and turbo, now have a annoying noise to. Sounds like a rattle/echoey noise coming from the turbo. It never did this before
    maybe we have the same problem?
    Also went out he other nite in it and it souned like it got noisey from the engine, possible manifold blow? What was the job like to do? are there any signs of a manifold blow, as it seems to boost fine etc.
    ENGLAND
    Re: Strange Rattle?
    i can put the video back on if you really want to hear it mr gttjames.. ..but mine sounded a lot worse than that mate, more like a tractor, still not sure if shes fixed yet, waiting on some help to bleed the coolant system. you could also check the clutch bearing, try a stainless steel gasket between turbo and manifold, etc and i think flywheels can become a little noisy aswell if not fitted correctly
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Strange Rattle?
    Quote Originally Posted by OUTLAW View Post
    i thought there was only one way to fit a fly wheel. bleeding the cooling system is easy open the bleed nipples on the top rad hose and on the water pump pipe fill the header tank up and lift it up in the air keep refilling the tank and eventually water will come out the nipples nip them up and fill to the max line. remember to you antifreeze as this also helps against corrosion.
    ENGLAND
    Re: Strange Rattle?
    cheers matey, i know how to bleed the cooling system, just waiting on a extra pair of hands............
    Cambridge
    Re: Strange Rattle?
    yer mine sounds like a tractor too.
    Won't be clutch release bearing as fitted a new one.
    Wont be flywheel as havnt touchd it, only changed clutch
    Non-member paul-11turbo's Avatar
    merseyside
    Re: Strange Rattle?
    I think the clutch bearing thing is the noise my car makes, like a funny squeeky noise that stops when i depress the clutch pedal.
    Will it eventually break and if so will the clutch stop working?
    ENGLAND
    Re: Strange Rattle?
    it will just get very noisey and sound really sh*it...had this happen to me in a xr3i many years ago....i still kept driving it...
    ENGLAND
    Re: Strange Rattle?
    Leicester
    Re: Strange Rattle?
    That sounds like the noise you get when the restrictors are missing out the t-piece on the breather system.
    Quote Originally Posted by gttjames View Post
    ENGLAND
    Re: Strange Rattle?
    could someone please put a picture on here showing the resrictor and where its located, so i can check.............thanks....
    Cambridge
    Re: Strange Rattle?
    yes me to please
    ENGLAND
    Re: Strange Rattle?
    managed to sort some pictures for you guys.....any suggestions?...sure its a standard fit... the old thread screws in fine, but the pipes been cut. new oil feed pipe?, or bodge old pipe?
    cheers scoff,..markey...
    Non-member Shane P's Avatar
    Jan 2006
    Re: Strange Rattle?
    Dude :
    ENGLAND
    Re: Strange Rattle?
    thanks G..., i have the bigger one in, which is located at the bottom of pic, but i donnot have the small one at the top of pic..... can i buy these, or do they come with the pipes?...thanks
    Jan 2006
    Re: Strange Rattle?
    60 01 007 478 - little one
    60 01 007 416 - big one
    Think they are still available from Renault, or your could try CGB
    Somebody will no doubt confirm the part numbers and availability
    Cambridge
    Re: Strange Rattle?
    ar i see, nice one ganja man. Did replace all of these with silicone jobbies so will look in my old pipes for them.
    Leicester
    Re: Strange Rattle?
    Resistor normally get sucked down the pipe so you dont even know its there!
    Milton Keynes - ish
    Re: Strange Rattle?
    the small one looks like a dust cap with a tiny hole in it, you could probably make one up
    Jan 2006
    Re: Strange Rattle?
    Both of mine got sucked down the standard pipes, which probably had something to do with the mashed plastic T piece. I just couldnt keep them in place and the car wouldnt idle properly.
    Cambridge
    Re: Strange Rattle?
    Quote Originally Posted by GanJaMan View Post
    Dude :
    went through my old pipes and had the one inthe top going to the back of carb. So fitted this and hey presto echo from turbo on tickover has gone
    but now that noise has gone turns out the manifold is abit noisy, and so is the cam chain
    Leicester
    Re: Strange Rattle?
    Least thats one problem solved then.
    Cambridge
    Re: Strange Rattle?
    yep. But not looking forward to doing manifold gasket, not sure what chain and tensioner will be like
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: Strange Rattle?
    Both not too bad to do, slightly fiddely but not too bad
    Whan doing the chain / tensioner, dont forget to put a rag or something in the half moon hole / gap in the side of the sump. When you remove the tensioner the backing plate likes to slip down and end up in your sump
    ENGLAND
    Re: Strange Rattle?
    rattles sorted, it was the manifold gasket, and i also got the turbo oil feed sorted, thanks to all that helped.....now where going to rag **** out of her...
    Cambridge
    Re: Strange Rattle?
    Quote Originally Posted by Kris M View Post
    will be looking out for that.
    Can you do the manifold gasket just by unbolting from turbo then unbolting from head, or will i have to take carb and bits off?
    been looking on parts
    is a genuine renault chain worth the extra?
    will i need to do tensioner aswell, might just do it while im there
    and on gsf the 'headgasket set' is cheaper than the 'prated head gasket' on its own?
    Apr 2006
    Swindon
    Re: Strange Rattle?
    Go to GSF for the chain and tensioner, yes its best to replace both together
    I didnt take my carb off when i replaced mine
    Feb 2001
    Rohtang pass
    Re: Strange Rattle?
    i just recently asked about this in this thread
