Results 1 to 30 of 30
    Feb 2012
    Nottingham
    No ignition and won't start
    So I was driving home and my temp an oil gauge went crazy then as I was driving I turned the ignition of and there was no lights so I drove home turned off the car and then nothing no lights on the ignition and the starter won't turn it's as if its dead.. It's not the battery as its new.. Would you say it's the alternator? Why won't the starter even try? Strange
    Dec 2011
    Re: No ignition and won't start
    I'd first check that your battery is holding power, volt meter required.
    If yes, then has got to be wiring issue. Check the wiring going to the starter (from battery). Have a looky around in case something has come loose in the engine bay.
    If no, then the alternator. Can check this using volt meter again.
    Also check fuses, just in case something has overloaded. In these conditions, people tend to have everything on, radio, heater on full, rear demister and lights!
    FYI:
    Battery should hold 12V and go upto around 14V (not more) when driving.
    Non-member SCHWARTZ's Avatar
    Wallington south london
    Sounds like a loose earth or something like that maybe to the starter or block etc... But if not an earth some kind of wiring fault.
    Feb 2012
    Nottingham
    In the last minutes of running on my drive the battery light flickerd iv checked quickly and everything seems tight but its bloody snowing that's what I love about these 5s it carried on got me home then gave up so atleast I'm not stuck out there today cheers guys..
    Feb 2012
    Nottingham
    What and were are the fuses? The parking light is on but the batterie light isn't also the oil pressure gauge isn't rising when I turn the ignition?? Strange!!
    Feb 2012
    Nottingham
    Also the fan won't bridge? Main lights are on radio etc
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    I know this sounds stupid but... Is your fanbelt still on? When I threw a belt once the temp gauge just shot up because the water pump wasn't turning.
    Feb 2012
    Nottingham
    At this point iv checked most things and my fingers are falling off and I look like frosty the snowman yep belts still on. My dads bringing the booster up and charger.. Iv found the fuse to the fogs is soaked and green so thats not good.. Is a strange one I'm only panicked as iv got bloody work at 5am and I ain't walking in this
    Committee Member
    Events
    Slammed 66's Avatar
    Nov 2011
    Grimsby
    Best of luck with it woody
    Dec 2011
    your a real man useing one of these everyday lol put hand on main lead and follow all the way to starter so you can feel if its shorted against something do the same on earth lead check it aint broke
    Leeds & South Yorkshire Area Rep
    Loose Bolts Tuning
    Robbo's Avatar
    brighouse
    Quote Originally Posted by chris View Post
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Stick a jump lead from your negative terminal and to the block, see if this cures it. if so then its a bad earth to the block, the alternator also has to be earthed, try the other lead from the negative terminal to the alternator body by the top brackets easiest.
    Sounds like the alternator or wiring to it has gone tits up and battery is flat, check the voltage when its running
    Check your main earth, jack the car up drivers side, take front wheel off and shine your torch at the back of the starter, there are two big wires coming off the back, check there both in good condition and tight
    Feb 2012
    Nottingham
    Did this and it clicked the starter that is.. What's next? Had enough tonight I'm freezing.. Thanks guys
    Sep 2005
    Parkgate Cheshire
    batterys probably dead too. sounds ;like bad earth has stopped the alty charging maybe? charge battery then retry with the leads on the block
    Feb 2011
    Down South
    sounds alternator id change battery or recharge old then check voltage with a meter a good alternator will produce about 14 volts if its not then the alternator is shot, also another trick i learned in garage game is get the car started with good battery remove earth on battery while running as long as alarm is ok to do this if car stays running alternator will be ok if it cuts out its 100% something to do with alternator or wiring follow this to the T and you wil get your answer paul
    Feb 2012
    Nottingham
    When I say clicked it blew the metal part off the jump lead a big blue spark.. Thanks guys will try more tomorrow.. Still got scaffolding all round the house so I can't get in the garage so it means getting out in the snow again.. Why didn't it doit yesterday thanks guys
    Sep 2005
    Parkgate Cheshire
    Sounds like your positive cables melted through somewhere then. battery negative to the block shouldnt create any kind of spark lol.
    Dartford
    It'll be worth checking the connector of death, it lives under the expansion bottle, behind the n/s headlight black in colour..
    Dec 2011
    Thats a dead short woody did you do as i said and run your hand down cables you will feel where/if its rubbed and touching check alt wireing
    Feb 2012
    Nottingham
    Will do tomorrow guys iv just got warm thanks for all the advise bloody snow getting in my way I really wanted to get some sledging in tonight aswell
    birmingham
    if the warning light is flicking then check both the negavite and postive conections on the alternator....take the conections off and check they have not split in anyway in the cold weather it can screw up the joints on the conections and i know on the alternator there pretty tight as well.haynes explains it pretty well on the ingition system pretty well and its simple.that can rule out any problems that you might have.....
    OR it can just be a renault thing and all will work tomorrow
    Non-member newbstar*'s Avatar
    canterbury
    Get AA membership! At least they will be able to volt drop test things and check for amp draw.
    Also you cannot check a wire just by looking at it and seeing if its tight
    Feb 2012
    Nottingham
    Quote Originally Posted by newbstar* View Post
    REALLY? wish id thought of that
    canterbury
    It's a way of getting someone with the tools and knowledge cheap! Just an idea being a tech/ aa man myself? Wait sorry melt a few wires more by putting jump leads on it lol
    Feb 2012
    Nottingham
    And the winner is... Correct snapped earth thanks guys.. Word to the wise renew your earths it's not worth getting caught out in the snow.. Doh!!
    canterbury
    Which one? Glad you found the fault
    Feb 2012
    Nottingham
    Firstly sorry for the sarcasm it's just I was freezing tired and coverd in oil. It was the one from the bulkhead on the drivers side to the engine.. I got 5mins in the daylight today and found it.. I hate these 5s at times but I love it more when it works.. Easy fix again
    Sep 2005
    Parkgate Cheshire
