Results 1 to 9 of 9
    Nov 2008
    which head gasket?
    Hi all,
    easy one...
    Which make of head gasket do people rate and where do you buy them from?
    ta
    J
    Non-member Misky's Avatar
    Oldham, Greater manchester
    Re: which head gasket?
    Just having my head skimmed today then time for a refit!
    I bought this:
    http://www.cgbmotorsport.net/group-a...-set-541-p.asp
    Cant really go wrong, lot of members on here buy from bob!
    Non-member Sy5GTT's Avatar
    Mar 2006
    Deepest Wilts
    Non-member Smitty's Avatar
    Nr Chelmsford
    You can get the so called up-rated one that the tuners sell from gsf or any motor factors.Its a Corteco gasket which is 1.9mm thick.Payne also do one which is the same thickness.
    Think gsf sell them for about £17+vat last time i got one.
    Corteco part number is 417429P
    Nov 2008
    Cheers!!
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    ive always used the corteco meillor ones that gsf sell.
    how ever ive noticed that corteco also do a gasket that is "uprated". this can also be confirmed by reading below what bb say about the one they sell -
    Up-rated Racing Head Gasket Set with Bolts
    The best gasket set for the GT Turbo, not to be confused with the Usual Meillor up-rated gaskets as sold by others. This is the coated Racing gasket which is more resilient to 'component creeping' caused by high boosts and high temperatures. We have used such gaskets at 50 Psi of boost making sure no detonation is present without any problems
    so could anyone that has bought this bb corteco headgasket post up the corteco part number please.
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    As good as the Meillor one is (and it is good), the o.e normal thickness gasket is more than upto the job, even when running plenty of boost.
    Dare I say it, as per the copper-core rad' thread from last night, that, again, Renault had it bob on right from the start...
    Oxfordshire
    Corteco only list one gasket for the GTT on their site, it's 1.9mm, and the standard Reinz gasket is 1.8mm (+0.15/-0.05), so pretty much the same. No point getting too excited over gaskets, contrary to popular opinion they don't cause much trouble on a GTT.
    Feb 2001
    Rohtang pass
    a while back sparkie told me that there is 2 different types that corteco do! unsure now
