Results 1 to 25 of 25
    Sep 2009
    meath
    Vacuum lines and a few other questions to get me running today!
    The workshop is now closed for two weeks so i've taken over a small corner to get my finger out and put the car back together,
    now its been over a year and 3 moves since i took it apart and in my project thread i was told some things are wrong.
    i'll start with this, what should be here? this is on the driverside of the gear box above the driveshaft cup
    second is the carb plumbing i've a single port actuator, and i've an avcr boost controller i've removed the anti perc setup too
    so what goes where?
    is this right?
    Re: Vacuum lines and a few other questions to get me running today!
    The speedo sensor goes in the hole in the box, a l shaped clip and cap head blot hold it in place.
    Sep 2009
    meath
    oh great i dont remember taking that off!
    Non-member rs250nut's Avatar
    I found the best way to sort the vacuum hoses up was a hose straight off the compressor cover going to the fpr, and then from below the throttle plate one hose straight to the actuator, if you want to mess about with a boost controller tee it in to the previous mentioned hose. I it were mine i would sack the boost controller off and set it up at the actuator, I used to find spool was improved without a boost controller/ bleed valve. Setup this way problems are alot easier to trace as you only have two pipes, also if you want to run a boost gauge have that on its own pipe.
    Sep 2009
    meath
    ok i have it back together the right way i think? but it refuses to take!
    i'm getting spark fine and i know the earths are good ( i even added a few.)
    problems i'm having are
    fuel pump not running it will run off a battery.
    my fuel, and oil gauges do not work, the oil one did work untill i cut off the perc fan wiring?
    does this look right?
    Dec 2011
    Are the plugs getting wet
    Sep 2009
    meath
    i'll be honest i should of checking but when the starter gave up i just walked away!
    i'll go out and check now!
    Is the tdc sensor connected, that would explain no fuel pump. It only runs when engine is cranking over/running.
    Sep 2009
    meath
    yup all connected up i'll check the earths from the eai again
    Dec 2011
    Sorry didnt read post propley the plugs wont be wet if fuel pump aint working the fuel pump realay can stick aswell open it and check its moveing
    Sep 2009
    meath
    i've bypassed all of the fuel pump wiring and just ran it off another battery
    Dec 2011
    Have you just rebuilt engine ok so get a cup and take fuel pipe off carb and run fuel pump for a few seconds and that way you definatly know pumps working
    Sep 2009
    meath
    the pump is working for certain justy not the wiring to it.
    the plugs are wet too!
    Dec 2011
    Ok and you have spark have you rebuilt engine just what have you done
    Sep 2009
    meath
    1 new liner, new rings, new bearings, new hg, tested head
    Dec 2011
    Have you had distributor drive out ? If your really stuck you could ring me and we can run through each pipe and check both cars are the same
    Sep 2009
    meath
    i did! i installed it like the good oul manual when fully seated the slot in the drive gear should be perpindicular to the block and the fat side on the right?
    my starter **** its solenoid so i wont have that fixed till at least the 3rd!
    i could ring you then?
    Dec 2011
    Which piston did you time it off ie what side of the engine bay but yea give me a ring anytime you can check all of the pipes i had my dizzy drive timed wrong and i was getting spark and no fuel i had timed it off wrong piston lol 07582131816
    Sep 2009
    meath
    I had the piston closest to the gearbox at tdc on the combustion stroke I think!
    Dec 2011
    Thats right also when you put dizzy drive in it roatates so you have to get it to stop on the mark do you know what i mean
    Sep 2009
    meath
    Yeah I've read enough storys about misfire's to pay extra attention to that! But it doesn't even
    Try to take! It it did however cough through the carb
    Dec 2011
    Yea sorry not trying to make out you didnt know what you where doin just running threw possibilities when they cough up carb i think thats timeing but could be wrong any chance it could be on wrong stroke i would definatly check pipe work again i dont mind running threw it with you some time
    Sep 2009
    meath
    Jaysus I know your tryin to help :-D it helps to have another mind at it! I'll double check the ignition timing tomorrow
    Dec 2011
    Quote Originally Posted by robx1r View Post
    Lol let me know
    Sep 2009
    meath
    bah!!!!! no spark now! seems to be getting fuel? and i changed out the dizzy and arm
