Results 1 to 25 of 25
    Non-member casper's Avatar
    Jul 2012
    afrs again
    Still a bit confused with the whole afr thing.When the boost gauge goes from negative to positive boost the afrs drop to 10s,is this when a smaller 1st stage would help?then it goes overly lean high 13s untill wot foot flat to floor,then they drop to 11.9.I no @ wot this afr should be ok its the bit in-between I'm not sure about.
    Jul 2012
    Re: afrs again
    Thanks for all the replies.Keep em coming.
    Dec 2011
    Re: afrs again
    i would of replied but i dont know what i am talking about
    Jul 2012
    Re: afrs again
    Quote Originally Posted by chris View Post
    Me neither mate,maybe that's the problem.
    Dec 2011
    Re: afrs again
    i just looked at your profile that is a smart car you got you will have to wait till one of the carb lads come on to help cos i wouldnt know where to start
    Non-member Jonny5's Avatar
    Sleaford
    Re: afrs again
    Im helping as much as i can on fb
    Didnt see the point in posting stuff up twice
    Jul 2012
    Re: afrs again
    [QvUOTE=chris;304769]i just looked at your profile that is a smart car you got you will have to wait till one of the carb lads come on to help cos i wouldnt know where to start[/QUOTE]
    Iv just read back what I first put and to be honest it does sound a bit gay,so to answer my own question.The rich afrs could be down to the acc jet doing its thing if not change 1st stage and check afrs,high 13s as boost increases are ok its wot that need to be right and as yours are 11.9 that's fine. Easy.lol
    Jul 2012
    Re: afrs again
    Thanks mate,it was good when I bought it but hopefully I'm making it even better.
    Sleaford
    Re: afrs again
    Quote Originally Posted by casper View Post
    would leave your 1st stage alone tho.
    Jul 2012
    Re: afrs again
    Quote Originally Posted by Jonny5 View Post
    I no you are Jonny and its much appreciated.Getting to the point where I don't feel like posting on here cos no one replies.Apart from GT JOSH and he just wants to bum me.
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: afrs again
    Nothing wrong with high 13s at part throttle casper, that's very nice for the solex !
    That blip to 10's could be the pump jet over active or the 1st stage too large as you say. Remember though, dropping the size of the 1st stage might lean off WOT too since 1st stage stays open even once 2nd stage is active. So a drop in 1st stage might mean you need to go up a bit on 2nd.
    Jul 2012
    Re: afrs again
    Thanks Chris.
    Jul 2012
    Re: afrs again
    So if I lower the boost will that effect afrs from spool up to full boost @wot.
    Non-member gttjames's Avatar
    Cambridge
    Re: afrs again
    same
    Jul 2012
    Re: afrs again
    Quote Originally Posted by gttjames View Post
    same
    James H.nice one.
    Non-member GT Josh's Avatar
    Mar 2012
    Boosting
    Re: afrs again
    Mate mine is high 13s before the blower spools up. 2nd stage is the enrichment for when the blower comes in. Your fueling is bang on dude.
    Jul 2012
    Re: afrs again
    Quote Originally Posted by GT Josh View Post
    About time.ha.Let me no when your mobile again and I will have a mooch over.
    Mar 2012
    Boosting
    Re: afrs again
    Another couple week and it will be ready
    Jul 2012
    Re: afrs again
    Had a play today and my actuator will only hold 16psi manifold anymore and I get big spikes or something,still plenty of fuel to play with 12s part throttle and 11@wot.So am going to have to bleed a bit off get another actuator,18-20psi should be spot on.I'm leaving it alone for now though.
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Re: afrs again
    mine spiked alittle when bleeding for extra boost, winding the actuator tighter helped keep the spike down.
    Jul 2012
    Re: afrs again
    I think its a spike Tony.There's not much adjustment left on the rod but any more preload and the boost goes from 16psi to silly boost?
    Sep 2005
    Parkgate Cheshire
    Re: afrs again
    try bleeding a little rather than adjusting the rod.
    Jul 2012
    Re: afrs again
    Yeah will do at some point,just going to leave it for now.I'm assuming that the actuator is not as strong as I thought,14psi stamped on it must be maximum.?
    Cambridge
    Re: afrs again
    i could only get about 14psi out of my actuator
    Jul 2012
    Re: afrs again
    Am I right in thinking we've got the same turbo James?
