Results 1 to 5 of 5
    Ivybridge
    EFi disaster!
    Hey all, need some help please!!!
    The rally car is poorly, let a friend borrow my wide band, and now he has wired it back in the car won't idle below 4k, literally with the throttle closed, revs clean from there but I am properly confused.
    Spec is bbpt EFi, with r19 ecu and all the Renault sensors....
    Any ideas???
    Re: EFi disaster!
    Sounds like he has upset some wiring or a sensor? Any pipes hanging off inlet causing an air leak?
    Non-member olidaviesuk's Avatar
    Nov 2008
    Bromley
    Re: EFi disaster!
    Unplug the wideband, if it runs then there is a
    Prob with the wiring there... Does it run closed loop with an ecu or just a gauge to monitor with?
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Re: EFi disaster!
    Quote Originally Posted by olidaviesuk View Post
    Oh yer mate it's a special meet it's even better when car crash turns up and gives out the hand jobs
    Ivybridge
    Re: EFi disaster!
    Gonna have a try at the weekend, has a closed loop 3 wire and innovate Afr too.
