Results 1 to 23 of 23
    Non-member gttjames's Avatar
    Cambridge
    advice on repairing windscreen surround, rot :(
    Well i couldnt put it off any longer, surround removed and windscreen.
    The outside seal was hard and didnt fit like iv seen other 5's so looks like its just been holding water from a previous windscreen repair. I removed a windsceen from a scrap 5 i have here, still had oe screen fitted. a pillars are fine but bottom is rotted on that. Shows if fitted correctly they last a while.
    Is this something that will be easily reapired by someone with the knowledge? I was going to cut the a pillars from the donor shell to use? But what about the bottom, any advice welcome
    Classifieds Moderator
    Mar 2004
    Re: advice on repairing windscreen surround, rot :(
    Mines a little like that so got mike to cut me one out a scrap 5.. I was gonna go in guns blazing but It was suggested to just drill out the spot welds and cut the minimum out the pillars so you only need to put some weld in the spot holes and then 2" of butt joint weld either side..
    Non-member GTphil's Avatar
    I'm dreading doing mine, from the outside mine looks a lot worse than yours, it's the last bit of Orange stuff that I need to sort, I will keep and eye on this thread and see how you get on.
    Moderator
    South East Regional Rep
    LiamR's Avatar
    Dec 1998
    Medway, kent
    I recently repaired mine. And am quite happy with how it looks..
    Mine was rotten around the bottom corners and at the centre where the seal meets.
    I cut the rust out with a cutting disc. Made up repair panels out of metal, welded them in. Considering I had never welded before it went ok tbh. I am quite pleased with the outcome.
    I have some pics on my camera at home. I'll upload them to my restoration thread when I get back from Vietnam
    Trader
    GT Turbo Spares co.uk
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Buy a new one
    Moderator
    LiamR's Avatar
    Dec 1998
    Medway, kent
    Didn't think u could get them new????
    Trader
    Jan 2001
    Morden
    Quote Originally Posted by LiamR View Post
    Picked 2 up recently
    Are they new ones Mike?
    Trader
    Jan 2001
    Morden
    Yes
    Nov 2011
    Were from ? Dealers ?
    Trader
    Jan 2001
    Morden
    Overseas stock clearance
    Nov 2011
    Ok can you let me know how to get one please ? Cheers
    Cambridge
    yes please as many progress pics as you can would be a big help
    Cambridge
    pm
    Cambridge
    i thought mine was bad... well whatever route i take il update with pics then as might help others
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    I was in the same situation when my car was being restored and I bought a screen surround from mike brand new and it fit like a glove the guys who done my body work told me it would have cost me more money and time for them to repair my old one than it would fitting the new one and also a year down the line you may find your get a rust patch come up in a different part of the surround to your repair. My honest opinion save your money and time and buy one from mike unless its cheaper doing it yourself
    Im wondering if these could be reproduced or at least a mould taken for future?
    Trader
    Jan 2001
    Morden
    I am happy to loan one of the onbes I have here to get it copied but someone else can foot the bill this time. As the upfront costs are usually alot unless you can order 500+
    Thanks
    Mike
    Apr 2012
    Denmark
    I would try Klokkerholm(.com) as mentioned earlier on here with the stills im quite shure they had them in production some years ago..
    They must still have the mold/die or what ever that thing they press them in are called..
    Apr 2012
    Denmark
    Im willing to give them a call to see if they can still make the surrounds..
    And ofcource the price..
    Cambridge
    woth a try, see what comes up
    Mar 2004
    cut some of mine out, few hours with a spot drill, grinder and wire wheel.. just gotta remove 2nd hand one then fit it
    Cambridge
    cheers for the pics, does help seeing it stripped down like that
