Page 2 of 2 FirstFirst 12
Results 51 to 64 of 64
  1. #51
    Non-member TNT ANDY's Avatar
    Re: running temp issues
    I would also get a stat installed.
  2. #52
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Quote Originally Posted by tubbyG View Post
    Ive never had a stat fitted for the 3 years ive ran it, and had no issues
    Bet you find winter driving a bit rough
  3. #53
    Feb 2012
    Nottingham
    new waterpump and stat ordered, I will hold off buying a hg untill I can rule everything else out.
    Renault put one in there for a reason bud and I'd say youve had issues lol read above for £17 it's worth having one in.. Eliminate everything
  4. #54
    International Area Rep
    Jul 2009
    Hungary
    I also have to check my cooling.
    Today I've noticed that the fan only turns on for 10-15 seconds than off.
    And start again in the next minute. But as I remember the temp switch in the
    radiator has a 10 degrees range where it should be kept ON.
    Could it be that the switch is not working correctly? Or the relay?
  5. #55
    Non-member tubbyG's Avatar
    Dec 2010
    Right then, Update!!!..... I have just had a new waterpump, headgasket and head-bolts delivered so I can get this sorted on saturday A few hours max I reckon!!
    Just waiting on a thermostat to arrive now, then to get some fresh oil and we're away!!
    I will be posting up pics of the headgasket for you guys to (hopefully) analyse
  6. #56
    Feb 2012
    Nottingham
  7. #57
    Dec 2010
    Just whipped off the water pump, and I have discovered the problem
    the fins on the inner wheel have completely sheared off the shaft and broke into a few pieces resulting in no water circulation. Will upload a pic later
    I am just putting on the new pump and will get it running to see how it fares. fingers crossed its solved - hopefully no need for h/g change
  8. #58
    Sep 2005
    Parkgate Cheshire
    fingers crossed for you :-) atleast you have found the cause if the gasket has gone
  9. #59
    Non-member Jonny5's Avatar
    Sleaford
    Great news mate, easy fix
  10. #60
    Dec 2010
    it seems I wasnt so lucky
    while running the engine to check temps the idle was pretty bad, it was very rich (10-11 afr) no mater how much I adjusted it and had the odd hesitation. Running temps were great though.
    Im guessing that there was coolant getting into the cylinder/s causing a weak burn making it so rich.
    so I have just removed the h/g but cant see any obvios signs of damage, but will get a pic up later. Just going to put in the new gasket, put it back together and see how it goes
  11. #61
    Dec 2010
    sucess!!! I have changed the h/g, waterpump, head-bolts, oil & filter and the 5 runs again! sweet as a nut too!
    here is a pic of the offending waterpump and the shiny new replacement
    the wheel was completley detatched from the shaft and as you can see, part of the wheel was missing....dont think it liked 7k rpm
    Im no expert but was unable to see any obvious damage to the h/g, but its changed now and fixed so wont upload a pic just now.
    ps....lowered the boost again to keep me safer!
  12. #62
    Feb 2012
    Nottingham
    Good news bud but what boost was you runnin? Just one thing how old was te pump?
  13. #63
    Dec 2010
    I have no idea on the age of the pump mate, was on the last engine when I bought the car (3 years ago). As it was running as it should I never felt the need to replace it - how wrong was I
    I had the carb set to run 22psi on a T28, but I had lowred it to 20psi untill I had det monitored. Now its down to a rich 18psi
  14. #64
    Sep 2005
    Parkgate Cheshire
    Lambda sensor measures the oxygen content in the exhaust so a misfire would show as a very lean mixture because of the unburnt oxygen regardless of how much fuels dumped in. Glad its sorted for you though
