Results 1 to 9 of 9
    Aug 2004
    Renault 21 or 19 16v wiper relay
    Long shot i know but does anybody have a wiper relay from a renaultn21 or a 19 16v..
    Re: Renault 21 or 19 16v wiper relay
    I should do. Let me have a nosy over the next day or two and I'll let you know.
    Aug 2004
    Cheers lewis
    Out of interest what fault are you getting with the wipers?
    Aug 2004
    They have a mind of there own (IE: constantly only or come on when ever ever they like), the stalk works ok... so amsure its the relay at fault...
    Have cleaned up all the electrics to ensure no wiring fault etc...
    bracknell
    you sure it not a fuse blown .. there are two fusses for the front wipers
    Aug 2004
    Quote Originally Posted by THE MASTER View Post
    2?? I have to plug a fuse in under the steering column to use the wipers atm... where is the 2nd fuse?
    Trader paul b's Avatar
    Jul 2002
    used to be anywhere, lol, but in the fuse box...not under the steering column...
    the 2nd usually also did some very random stuff, like the cigarette lighter illumination and some other auxillary items, it works through the park side of the motor feed...
    just check all the fuses 1 by 1 just to narrow out a random electrical fault, not like a renault .
    Aug 2004
    Cheers Paul, I will check tomorrow.
