Page 2 of 2 FirstFirst 12
Results 51 to 63 of 63
  1. #51
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: Engine conversion
    C1J FTW
    Keep it real, keep it original
  2. #52
    Non-member GT Josh's Avatar
    Mar 2012
    Boosting
    Quote Originally Posted by Tony Walker View Post
    so can he get full throttle in 3rd?
    Yes but only if he goes through the rev range so to speak. But still some spin as the t28 comes in. Harsh kick of the boost
  3. #53
    Non-member GTphil's Avatar
    Full throttle on the road in third is hard work
    In some of these 400hp valver lumps surely only fifth has decent traction on the road.
  4. #54
    Ireland Area Rep turbo ted's Avatar
    Ireland Co. Kilkenny
    I think if you pushing well over the 300ft lb of torque a standard JC5 box won't last, Turbo Teds JC5 i had built for him lasted a good year a half although it did finally end its life recently due to the power and torque that car is putting out now but before then held well
    How long it last will come down to driver too
    this is what happened to my jc5 with 360ft lb of torque with a lsd pics below
  5. #55
    Motech Tony Walker's Avatar
    Sep 2005
    Parkgate Cheshire
    Thats good news then? the box is still intact?
  6. #56
    That is one minced box/shaft
    Was that at pod last weekend?
  7. #57
    Sep 2005
    Parkgate Cheshire
    Geusing you can just swap the diff then is it an LSD?
  8. #58
    that box is finished its snapped the spline shaft off the lsd and destroyed the passenger driveshaft theres nothing else i can do to make it stronger time for vag box conversion.
    damage was done at pod last week when i launched
  9. #59
    Sep 2005
    Parkgate Cheshire
    yeah i heard the vid, the lsd worked well, snapped one locked snaped the other lol
  10. #60
    norwich
    Quote Originally Posted by turbo ted View Post
    oouuchhh!!
    welcome to the 02m 6 speed club, just out of interest how many outer hub splines have you mashed
  11. #61
    Quote Originally Posted by HAndy View Post
    oouuchhh!!
    outer hub splines none this year as i done the 172/182 hub conversion,if your still using 5 hubs and the ends of 5 driveshafts they will snap clean off.
  12. #62
    How times have moved on! Driveshafts used to be almost indestructible!
  13. #63
    Mar 2012
    Boosting
    That's ****in nuts teddy. Deary me.
